AVForums.com is the UK's biggest & best home consumer electronics discussion resource
Go Back   AVForums.com > Home Entertainment Players and Recorders > DVD Recorders, Recording and Media
LinkBack Thread Tools Display Modes
Old 05-12-2004, 7:18 PM   #1 (permalink)
stuart_day64
Posts: n/a
Smile Which DVD recorder with a budget
Hi there,
So this christmas i have decided to take the plunge and buy a dvd recorder. I would like one which has good disc compatability and with a DV in put so i connect my Panasonic DV camcorder to it. I have a budget of roughly 300 and i have been searching the internet for machines that fit this criteria. I have been put off Panasonic machines as the DVD ram format is not compatible with some players that i would be using.
I have currently got my eyes on the SONY RDRGX700 but i was wondering if anyone hasd any thoughts on this or any other machines i should look at.
Stu
Old 05-12-2004, 7:34 PM   #2 (permalink)
Thanks: Gave 0, Got 7
Originally Posted by stuart_day64
Hi there,
Stu
After extensive research on the Sony machine - don't buy it - its got a lot of features missing. I've been a Philips fan for about 3 years and I still have two machines but a couple of weeks ago I bought a Pioneer DVR420 which is a fine machine with great editing facilities. However you will need the 520 model with the DV input but that won't fit your budget. A lot of people diss the Philips machines but you could get a DVDR75 with DV input but it has no hard drive. This is what I've been using for two years capturing from my Sony digital camcorder.
dmpoole is offline   Reply With Quote
Old 05-12-2004, 7:42 PM   #3 (permalink)
GASJKH2
Posts: n/a
Which Camcorder
Stick with a Panasonic dude - by far the best made machines on the market (the dvd trade competition even admit this) - although a bit more expensive! Not far behind though is the Tosh XS32 which is cheaper, good machine though .
Old 05-12-2004, 7:56 PM   #4 (permalink)
stuart_day64
Posts: n/a
Exclamation
What features inparticular arte missing???? I know sony is a bit more expensive but i have had great reliablility from them over the past 25 years as well as great quality
Old 05-12-2004, 9:43 PM   #5 (permalink)
Thanks: Gave 1, Got 1
If this is a Sony HDD machine it has the much needed DIVIDE function missing from the HDD.No bulk copying because you cannot divide a long recording into individual programmes.
Sony recorders are generally way overpriced.For the price of a Sony dvd only machine you can get a Toshiba one with HDD for a few pounds more
phelings is offline   Reply With Quote
budget, dvd, recorder
Refbacks are On
AV ForumsOptimised for Firefox.
