Hi all,
Just wondering on the best way to connect up my Panny E55 to my 32 integrated Freeview Panny 32" LCD. At present, it is
Main TV Roof Arial > E55 Arial In
E55 Arial out > LCD Arial In
E55 AV1 (TV) to LCD AV2 (set as Qlink, Monitor (should this be DVB?)) using Scart
Somehow i am not convinced this is right?
All i want to do is have the easiest and correct way to record freeview onto the recorder and use the E55 as a dvd player (can i also use component out from E55>LCD AV4 Component in for playback?)
Any help mucho appreciated.
Ta
Sunil
