AVForums.com is the UK's biggest & best home consumer electronics discussion resource
Go Back   AVForums.com > Home Entertainment Players and Recorders > DVD Recorders, Recording and Media
LinkBack Thread Tools Display Modes
Old 04-12-2004, 6:46 PM   #1 (permalink)
oldie
Posts: n/a
Unhappy Tosh XS32 setup problem?
Set up my Tosh XS32 yesterday but have problems with satellite info. The set up is as pp18 of the Installation Guide :-
Panasonic Satellite TV Scart -> Tosh AV2
Tosh AV1 Scart -> Sony TV
My problem is that I can record the analogue channels to the HDD - but the satellite channel only has audio but no video (and records that way). If I select SATMON I get the video (but I imagine that this merely bypasses the Tosh circuitry).
The AV2 input is set to RGB & the AV1 output is set to S-video (to correspond with the SCART on the TV)
It may be finger trouble; I could not make much progress with the manual channel setting of the SAT channels. Which is the 'Guide Channel' on Sky?
I'll call the Toshiba helpline on Monday if these problems are unfamiliar in AV forums
Old 04-12-2004, 7:58 PM   #2 (permalink)
Thanks: Gave 0, Got 4
Make sure the Sky Box is setup to output RGB.
Then avoid using the "TV" button on the Sky remote as this temporarily flips the box back to composite video output. If this happens, pushing the "Sky" button should take it back to RGB.
johnjackthom is offline   Reply With Quote
Old 04-12-2004, 10:27 PM   #3 (permalink)
oldie
Posts: n/a
Thanks - the RGB o/p gave me the video - but it's not in colour! At least the box doesn't have to go back.
I still have to sort out the manual settings for SAT and get the infrared gizmo to work
Old 05-12-2004, 1:38 PM   #4 (permalink)
If its not in colour it probably means the Televisions AV connection is expecting Composite Video while getting S-Video.
If possible, try using an RGB scart on the TV as this will give better quality and may avoid problems when the DVD recorder is in standby.
problem, setup, tosh, xs32
Refbacks are On
AV ForumsOptimised for Firefox.
