AVForums.com is the UK's biggest & best home consumer electronics discussion resource
Go Back   AVForums.com > Home Entertainment Players and Recorders > DVD Recorders, Recording and Media
LinkBack Thread Tools Display Modes
Old 27-11-2004, 7:27 AM   #1 (permalink)
Panasonic DMR-E60 and Remote Code
My sister recently bought the said unit and accidentally change the remote code on the unit to dvd 2. Now the remote ceases to work. when i press any button on the remote, the unit displays "REMOTE DVD 2". can't even acess the setup to change it back. the manual does'nt help either.
any help would be appreciated.
lunaTECH is offline   Reply With Quote
Old 27-11-2004, 7:38 AM   #2 (permalink)
Rasczak's Avatar
Thanks: Gave 420, Got 533
Use the front panel to access 'Functions' and then goto 'Setup', 'Settings' and then switch 'Remote' to "DVD1". If the handset itself has been reset to DVD2 you have to do something along the lines of press 'Enter' and then '1' - it is explained somewhere in the manual.
Rasczak is offline   Reply With Quote
Old 27-11-2004, 9:23 AM   #3 (permalink)
thanks.
Old 27-11-2004, 11:29 AM   #4 (permalink)
Thanks: Gave 4, Got 22
As Rasczak says just press enter and hold 1,2 or 3 to alter the remote to match the unit, note you have to hold for at least 2 seconds or it doesn't work.
bobcar is offline   Reply With Quote
code, dmre60, panasonic, remote
Refbacks are On
AV ForumsOptimised for Firefox.
