Go Back   AVForums.com > Home Entertainment Players and Recorders > Blu-ray and DVD Players > DVD Players
Today's price checkPowered by
Sony DVP-FX730
LG DRT389H
Panasonic DMR-EX769 160GB
LG RHT497H 160GB
Sony DVP-FX730
LG DRT389H
LG RHT497H 160GB
Philips DVP3310
Panasonic DMR-EX98V 250GB
Panasonic DMR-EX79 250GB
Samsung DVD-H1080
Panasonic DMR-XS350 250GB
Sony RDR-HXD995
 More...Prices updated November 22nd at 2:30am and include delivery.
Old 07-10-2003, 11:10 AM   #1 (permalink)
denon2900sdi
I have just seen a Denon2900 dvd for sale for £1200, mine only cost £660 but this stated it had SDI ( serial digital input) does anybody know what this is and can the old one be upgraded if worthwhile.
thanks Paul
PAUL RODGERS is offline   Reply With Quote
Old 07-10-2003, 11:12 AM   #2 (permalink)
sorry SDI stands for Serial Digital Interface output which maybe they all have and this website was very expensive
Denon dvd 2900, Morduant Short THX speakers,Pioneer VSX2001 amp,Pioneer SXE Plasma , SKYHD and now PS3 WOW, MEDION BLU RAY PC
Old 07-10-2003, 2:49 PM   #3 (permalink)
Dutch's Avatar
Thanks: Gave 226, Got 108
Hi Paul,
SDI will carry a digital interlaced picture from the MPEG decoder before the video DAC stage. These non-copy protected signals will be 480i or 576i depending on NTSC or PAL discs - DVI isn't able to carry these signals. The interlaced signal would be passed to a deinterlacer/scaler for display to a plasma or projector. Have a word with the guys at www.jvb.nl who may be able to mod your 2900. Hope this helps.
Steve
Sky HD, Pioneer LX5090, BDP-05FD, AX4ASi, Oppo BDP-83, Toshiba HD-XA1, XE1, Sony HXD910, Kef iQ7SE (front), Kef iQ6C (centre), Kef Q55 (rear), SVS 2039PC+, Harmony 1000, with Kimber, Supra, Molex and BlueJeans cables
Dutch is offline   Reply With Quote
Old 07-10-2003, 4:49 PM   #4 (permalink)
Thanks Steve,
could not get my head around what it actually means even when looking on the internet, lots of referencing but no hardcore explanations( or am i stupid).
If you have a SDI output what kind of input does your plasma need. I would be grateful if anybody has this equipment to post there views.
All i want is a better picture without buying a new plasma
thanks Paul
Old 07-10-2003, 5:35 PM   #5 (permalink)
Dutch's Avatar
Hi Paul,
There is only one plasma manufacturer that has put SDI on them - Electrograph Delphi - but this model is a couple of years old now. As I said before, you would need a deinterlacer/scaler with an SDI input, and preferably a DVI output. This would give a pure digital signal from DVD to screen. A scaler that can do this is the Focus Enhancements CS-2 with optional SDI input board - I'm considering one myself. See here for more info:
http://www.ivojo.co.uk/focus-enhance...stage-cs-2.htm
Hope this helps.
Steve
Old 09-10-2003, 1:28 PM   #6 (permalink)
Thanks: Gave 5, Got 0
Dutch,
I'd also like to know a little more about SDI.
Whats the advantage in sending an interlaced signal via SDI to a de-interlacer/scaler as opposed to a DVI connection where the signal has been de-interlaced/scaled at source?
Is it that the processing can be done outboard by that expensive box you included a link to ?
If you've (or anyone) have compared a SDI and DVI connected system, can you highlight the resulting picture differences between the two ?
n.
HouseofMu is offline   Reply With Quote
Old 09-10-2003, 5:58 PM   #7 (permalink)
Dutch's Avatar
Yes, the advantage is that the deinterlacing and scaling can be done by a device of your choice, such as the CS-2. I'm afraid I've not seen the SDI output from my 757Ai, so I can't really compare it to the scaled 768p DVI from my Momitsu.
Steve
denon2900sdi
