3.5 million visitors each month
Go Back   AVForums.com > Home Entertainment Players and Recorders > Blu-ray and DVD Players > DVD Players
Latest popular product pricesPowered by
Panasonic DMR-EX769 160GB
Coby TFDVD7008
Samsung DVD-H1080
Sony DVP-FX730
Coby TFDVD7008
Samsung DVD-H1080
Sony DVP-FX730
Panasonic DMR-EZ48
LG DRT389H
Panasonic DMR-EX98V 250GB
Panasonic DMR-XS350 250GB
Panasonic DMR-EX 89 400GB
Toshiba RD-XV59DT 250GB
 More...Prices updated March 16th at 12:30am and include delivery.
Old 07-10-2003, 5:00 AM   #1 (permalink)
Thanks: Gave 9, Got 89
Pioneer 656 - PAL from NTSC ???
I may have misunderstood, but I read on a recent thread on here that some players allow you to select which format is output. Does this mean that if I am playing a R1 disc which is obviously NTSC that I can select that it is output as a PAL signal ? The thread mentioned that some players have a switch on the rear, and others are switched in the set-up menus and it is to cater for people whose TVs can't cope with dual format.
Anyone know if this is correct, and how it's done on a 656 ??
davidwatsonok is offline   Reply With Quote
Old 07-10-2003, 7:25 AM   #2 (permalink)
monsieurblack's Avatar
Thanks: Gave 14, Got 1
not too sure sorry...
not in front of mine atm, but from what i can recall it outputs my ntsc discs as pal60 as the current tv isn't able to recieve a straight 'raw' ntsc signal and displays it in black n white but using this player i have no problems.
sorry i can't be of more help...just how i understood it [old telly u you see and had to take back my multi-region sony and exchange for this pioneer as it had the correct output ]
let me know if you find out how
cheers
monsieurblack
Signature removed by Admin
monsieurblack is offline   Reply With Quote
Old 07-10-2003, 7:27 AM   #3 (permalink)
Super Moderator
Thanks: Gave 612, Got 1,101
TV signals can be defined with three factors:
Number of scan lines
Frame rate
Colour carrier.
The colour carrier is irrelevant when RGB or component signals are used. It is only relevant with Composite and SVideo.
An NTSC signal is 525/60/NTSC
A (true) PAL signal is 625/50/PAL
Although I can't speak for the 656, most Pioneers do indeed have an option to switch output formats. However, when set to 'PAL', and when playing an NTSC disc, the signal being output via composite and SVideo is
525/60/PAL
which is a hybrid signal - it has the normal NTSC line and frame structure, but with a PAL colour carrier. It is for use with most modern PAL only TV sets which CAN interpret the line and frame structure of NTSC, but not it's colour carrier. It isn't necessary to use such a setting if the TV can interpret NTSC fully, nor if RGB or component signals are in use. And this hybrid signal cannot normally be recorded on a PAL only VCR - these typically require the true PAL line and frame structure to work.
525/60/PAL is also known as 'pseudo PAL', or 'PAL60'.
Nigel
Except on matters of forum moderation, the views expressed in this post are my own, and do not necessarily reflect the opinions of AVForums.
LV426 is offline   Reply With Quote
Old 07-10-2003, 7:37 AM   #4 (permalink)
Thanks: Gave 21, Got 42
Yes this can be done on the 656a from the front panel, rather than a switch as with the older models of pioneer.
First switch the player to standby, then hold down the "forward" chapter button to change the setting.
You may need to repeat for each change you wish to make.
It should cycle through AUTO->NTSC->PAL->
Obviously you want to select PAL.
If this is not clear take a look at page 20 of the manual.
Your TV will still need to be able to cope with PAL/60 signals though, but this should not be problem for newer sets
mseabroo is offline   Reply With Quote
Old 07-10-2003, 7:38 AM   #5 (permalink)
Reiner's Avatar
Thanks: Gave 2, Got 12
Just to add that it depends on the make and model, the following outputs are possible (from 525/60):
PAL50
PAL60 (Pseudo-PAL)
NTSC
What is output and if it can be changed depends on make and model.
Old TV's may only understand PAL50 though most of the time you can also watch NTSC in color if DVD player and TV support RGB via Scart, given the TV can handle 60Hz sources. All you then need is a fully wired Scart cable.
Rgds,
Reiner
Reiner is offline   Reply With Quote
Old 07-10-2003, 1:28 PM   #6 (permalink)
Thanks for the info guys. Just tried the "track fwd" one and it does work, but as mentioned by Nigel it doesn't work when outputting to VHS. Guess it's PAL60 only. Oh well, looks like I need an NTSC-PAL converter.
Old 09-10-2003, 7:36 AM   #7 (permalink)
Super Moderator
....and that will be very expensive - at least GBP200 for a cr@p one; say GBP700 for a half-decent one, and GBP30000 ish for a broadcast quality one.
If you really need a true PAL (625/50/PAL) signal off an NTSC disc, the cheapest way to do it is to buy a cheapo chinese DVD player from a supermarket many of these DO output true PAL from NTSC discs.
Nigel
Old 09-10-2003, 10:58 AM   #8 (permalink)
Can you name any specific brands?
Live fast, drive faster !
Old 09-10-2003, 11:10 AM   #9 (permalink)
Thanks: Gave 23, Got 11
Would changind the output to PAL, get over the problem with horizontal banding lines on Panasonic TV's with NTSC RGB material?
higenbs1 is offline   Reply With Quote
Old 09-10-2003, 12:09 PM   #10 (permalink)
Super Moderator
Originally posted by me!
The colour carrier is irrelevant when RGB or component signals are used. It is only relevant with Composite and SVideo........ It isn't necessary to use such a setting if the TV can interpret NTSC fully, nor if RGB or component signals are in use.
Nigel
656, ntsc, pal, pioneer
Copyright © 2000-2010 M2N E. & O. E.
