I'm using this player connected directly to my TV via s-video and I have a perfect picture..R1 & R2.
1. Can you connect directly to the TV just to see if it's a problem the amp is introducing?
2. Try using another type of cable...component, composite or scart to see if it happens with those. If these are ok it might be a problem with your cable so you could try another s-video cable if the new cable doesn't work it must be a dodgy player.
I notice the picture does flicked B&w then colour then a disc is first inserted. I think it happens when the machine is switching between regions.
P.S. I'm also using component to a ISCAN which then goes to my projector and that is fine also.
