Go Back   AVForums.com > Home Entertainment Players and Recorders > Blu-ray and DVD Players > DVD Players
Today's price checkPowered by
LG DRT389H
Sony DVP-FX730
Panasonic DMR-EX769 160GB
LG RHT497H 160GB
LG DRT389H
Sony DVP-FX730
LG RHT497H 160GB
Philips DVP3310
Panasonic DMR-EX98V 250GB
Panasonic DMR-EX79 250GB
Panasonic DMR-XS350 250GB
Samsung DVD-H1080
Sony RDR-HXD995
 More...Prices updated November 24th at 4:30am and include delivery.
Old 25-08-2003, 5:41 PM   #1 (permalink)
Dave777's Avatar
Thanks: Gave 19, Got 9
Sony 930 Multiregion
Is it true this can be made mutiregion with a remote control. If so does anyone know how? I've done a quick web search and found a company who will send you a remote control to do it, then you send it back to them.
Dave
Dave777 is offline   Reply With Quote
Old 25-08-2003, 7:22 PM   #2 (permalink)
Thanks: Gave 7, Got 23
Yes but it's a very long code, not very easy.
cybersoga is offline   Reply With Quote
Old 25-08-2003, 9:35 PM   #3 (permalink)
Dave777's Avatar
Thanks for your reply. Would you be prepared to list the technique here? Can the code be entered with a Pronto remote? Hopefully I will buy this multiregion, but my local supplier doesn't do them I think. They are checking!!
Dave
Old 25-08-2003, 10:08 PM   #4 (permalink)
Thanks: Gave 4, Got 0
I did my 930 with my pronto and code from www.dvdrhelp.com .
Ill get the code if you like but off to bed right now
manc is offline   Reply With Quote
Old 26-08-2003, 8:19 AM   #5 (permalink)
If your local dealer can make other Sony's multiregion, then they should be able to make the 930 multiregion as it is the same code. Search the forum the code has been posted many times before.
Old 26-08-2003, 8:55 AM   #6 (permalink)
Dave777's Avatar
Thanks I did find it on www.dvdrhelp.com and I didn't search this forum...DOH!!
I was about to order a Denon 2900, but I think I'm going to get one of these for now and upgrade next year when Denon's release their silver range (or I find a recorder I like!)
Dave
930, multiregion, sony
