| Re: Will I see a difference with a new DVD player?
You may well see improvement, but perhaps not as massive as you might imagine........provided that your existing kit is giving of its best. Assuming equally correct adjustment in either case, the difference between HDMI and a properly configured RGB connection is not huge.
So I'd suggest, the first thing to do is ensure you are getting the best out of your existing kit, before you go buying a new one. You may, for example, be getting a composite video feed between your DVD and the TV. You should do ALL of these things; any one of them not done right will cause composite video, which is poor.
- use the TV SCART output on the recorder (not, say the VCR output if it has one)
- in the recorder's menu, set the TV output SCART to output RGB. See the manual if necessary.
- ensure the SCART cable being used has all 21 pins connected up. Most do, but some/few don't. It doesn't mean you have to spend a fortune.
- use an input on the TV that is RGB enabled. See the TV manual
- if necessary (usually, it isn't, but do check the manual) set the TV to RGB for this input.
Once you've done all that - go back to step 2 and change it back to Composite or Video or whatever it's called. Compare with the picture from RGB. If you see no difference, then one of the other 4 points is still wrong. If you see a difference, set it back to RGB and leave it there.
Now return to your TV and turn off or down or to their mid (null) value and sharpness enhancers, detail enhancers, noise reducers etc. And set brightness and contrast to a comfortable level.
Any good?
Nigel Except on matters of forum moderation, the views expressed in this post are my own, and do not necessarily reflect the opinions of AVForums. |
