29-12-2008, 10:17 PM
#1 (permalink)
Thanks: Gave 4, Got 0
Is my dvd player faulty?
I Have just got an LG DR 385 dvd recorder,it plays div x, copied dvd`s,but when i play an original dvd i get horizontal band of colours flashing on and off every couple of seconds.This only happens with Original disks
Is it faulty and should i return it ?
cheers
29-12-2008, 11:03 PM
#2 (permalink)
Thanks: Gave 13, Got 27
Re: Is my dvd player faulty?
It may be that the macrovision protection is activated for some reason when it should not be. The macrovision activates if it thinks that someone is trying to make a copy of the original.
Or else it may be the cable, im asuming you have a hdmi one. Try a different one.
If it is definitely not the cable i would take it back to the shop.
29-12-2008, 11:05 PM
#3 (permalink)
Thanks: Gave 52, Got 692
That's the macrovision copy protection pulsating.You're either trying to copy a disc,or you have it plugged into the wrong socket on your tv.
... and I said to the nurse, 'you can take that free tetanus shot and shove it'.
AX100,84"Beamax screen,Sony 5200ES 7.1,XE1,PS3,Denon1930,Pioneer 600,Pioneer 575,JVC MX10,Sony 910 minidisc,Pioneer 925 laserdisc player,Mission 754 Freedom's,753's,Kef 200c and Canon V100's,2 Q100'S.
29-12-2008, 11:54 PM
#4 (permalink)
It is connected by hdmi and there is only 1 hdmi output on the t.v ,i am just putting the disk in and pressing play,i wouldn`t know how to copy a disk on this player.
thanks for the help
29-12-2008, 11:58 PM
#5 (permalink)
Ok then,how about changing the resolution output of the recorder?
30-12-2008, 12:17 AM
#6 (permalink)
i`ve tried 576,760 and 1080 and still the same band of colour flashing up
30-12-2008, 12:26 AM
#7 (permalink)
This may sound odd,but can you try a scart lead?
30-12-2008, 1:00 AM
#8 (permalink)
Yes i have just tried a scart lead and it plays fine with no flashing colour any more,could it be the hdmi lead?
30-12-2008, 1:08 AM
#9 (permalink)
Yep,it definitely could be a handshaking problem with your tv.
Good to hear it works.
30-12-2008, 9:40 AM
#10 (permalink)
Thanks Ian,does that mean i should try another cable then?
30-12-2008, 11:40 AM
#11 (permalink)
As long as you can return it if it doesn't work,then yes,try another cable.
