Go Back   AVForums.com > Home Entertainment Players and Recorders > Blu-ray and DVD Players > DVD Players
Today's price checkPowered by
Sony DVP-FX730
LG DRT389H
Panasonic DMR-EX769 160GB
LG RHT497H 160GB
Sony DVP-FX730
LG DRT389H
LG RHT497H 160GB
Philips DVP3310
Panasonic DMR-EX98V 250GB
Panasonic DMR-EX79 250GB
Samsung DVD-H1080
Panasonic DMR-XS350 250GB
Sony RDR-HXD995
 More...Prices updated November 22nd at 8:30am and include delivery.
Budget stand alone upscaler? donjon1966 Video Scalers, Video Processing and Progressive Scan 5 20-07-2008 4:17 PM
best multiregion upscaler on a budget? brandondanger DVD Players 5 05-07-2007 7:05 PM
New,budget HDMI Upscaler vs second hand non-upscaler. joffy1780 DVD Players 0 30-12-2006 5:06 PM
Is the Samsung DVD-HD860 a good budget upscaler? Deano@Dublin DVD Players 7 11-11-2006 8:47 AM
Mid Budget Upscaler or Helios X3000 - Picture quality ayh20 DVD Players 0 18-10-2006 4:32 PM
Old 10-12-2008, 3:54 PM   #1 (permalink)
Thanks: Gave 6, Got 12
Budget DVD Upscaler
I am just about to purchase my first LCD TV, namely the well recommended Sony KDL 32V4000.
So as an extra I thought I should invest in a DVD upscaler to make the most out of my 300+ DVDs.
I am not looking to spend much more than £80, hopefully at RS where I am getting the TV so I can "negotiate" some sort of deal.
So I am looking for a recommendation for a good player I should be going for.
Thanks in advance
Thebouy is offline   Reply With Quote
Old 10-12-2008, 7:49 PM   #2 (permalink)
fruitfly's Avatar
Thanks: Gave 39, Got 89
Re: Budget DVD Upscaler
The Onkyo is a very good upscaler.
ONKYO DVSP406-BLK at Richer Sounds - HI-FI Separates, Home Cinema, Speakers, MP3 DVD Portables, Plasma LCD, etc.
Although Superfi are having a special on this right now if you buy online. ONKYO DVSP406 DVD PLAYER (MULTI-REGION) - available from Superfi UK Visit http://www.superfi.co.uk/index.cfm/page/moreinfo.cfm/product_id/4458 for details
LG 42LG7000, Onkyo 605, Mordaunt Short Premiere 7.1 speaker set up, Pioneer DV400, PS3 60gb, Logitech Harmony One, PS2, Sony slv se710 VCR, one wallet, slightly dented!
My Collection
fruitfly is offline   Reply With Quote
Old 10-12-2008, 8:12 PM   #3 (permalink)
Thanks: Gave 38, Got 85
Personally would go for a Sony dvd or dvd recorder the scaler in my Rdr-hxd1070 is excellent, the sounds not bad either,
I'm sure the scalers are very similar to the dvd players.
THX 10.2 Arcam Av9 + Yamaha Z9 Nad M25 / 216THX Arcam 7/8P/P75/Dv135/Cd36 C.A.C500 Pioneer Pdr555rw/609 Panasonic PH10-50 Ptax100 150" screen Kef Q55.2/Q60/Q85/Q95x4 Mission 77Ds Paradigm PS1000x3 DIY Jl 13w6x2 Behringer EP2500/BFD/DCX 2496x2/CX3400x2
Import racer is offline   Reply With Quote
Old 11-12-2008, 9:39 AM   #4 (permalink)
Thanks for the info, will challenge the guys in RS to give me a deal on the Onkyo
Old 11-12-2008, 5:33 PM   #5 (permalink)
Thanks: Gave 0, Got 3
I've just purchased this Sony player from Superfi - the Sony DVPNS708H and am impressed with it:
SONY DVPNS708H DVD PLAYER (MULTI-REGION) - available from Superfi UK Visit http://www.superfi.co.uk/index.cfm/page/moreinfo.cfm/product_id/4263 for details
£68.46 delivered for multi-region. Mine arrived 24 hours after ordering.
This player has 1080p over HDMI and should work nicely with your TV - the player is Bravia Sync compatible if your TV has this facility ?
Sanyo Z3, Samsung DVD-HD850, Humax 9200t PVR, Sony HT-SL5 Amp. JVC AV28R Widescreen TV.
dmjohnson123 is offline   Reply With Quote
Old 16-12-2008, 9:59 AM   #6 (permalink)
Is the Sony multiregion when it comes or does it need "unlocking"?
I have the Sony KDL 32V4000, so I believe it has Bravia sync!
Old 16-12-2008, 11:02 AM   #7 (permalink)
I don't think the Sony can be made multi-region at home (using a 'hack'). You need to purchase it multi-region if you want it multi-region. As mentioned in my previous post it can be had from Superfi for £68 delivered and they do the upgrade so when you receive it from them it is multi-region out of the box.
Other suppliers can also supply this player multi-regioned, I bought mine from Superfi - delivery for me was next day.
Old 16-12-2008, 11:58 AM   #8 (permalink)
Great, I had read of a few people who had bought it on amazon and ended up with a non multiregion version.
So will look to get it from SuperFi.
Old 16-12-2008, 12:29 PM   #9 (permalink)
Thanks: Gave 176, Got 563
As far as I know, no Sony DVD player can be made multiregional with a hack and all of them have to be chipped to achieve this.
mjpartyboy is offline   Reply With Quote
Old 16-12-2008, 3:33 PM   #10 (permalink)
Thanks: Gave 10, Got 49
My Sony NS76H could be made region free with a One for All remote programmed with special codes and I see that the DVD Player Hacks forum also has a thread for the NS78 as well as the NS76.
Bolander is offline   Reply With Quote
Old 16-12-2008, 5:55 PM   #11 (permalink)
With Superfi selling the NS708 for £68 already multi-regioned I wouldn't bother buying it hoping it could be done at home.
I got my fingers burnt long ago when I bought my first DVD player, a samsung. I had read on all forums this player could be multi-regioned using a handset hack, bought the player and then found that mine had a new chipset which meant it couldn't be multi-regioned at home !!! I've always bought my players multi-regioned from a supplier since then. Once bitten, twice shy !
Old 19-12-2008, 8:32 AM   #12 (permalink)
miltsharman's Avatar
Thanks: Gave 18, Got 8
Have you checked out the Toshiba x500? Its now 1p cheaper than £60 at comet.
"Dont touch the RED button"
TV =Panasonic 50PX60B; AV Receiver =Onkyo TX-SR674E; Games=Xbox360; Speakers=Mordent Short Genie 5.1 system; DVD player=Helios X5000; Cable=Virgin V+ box ; Satellite= Fortec Star Pasion; Media Player= Istar mini; MP player=Zune80
miltsharman is offline   Reply With Quote
fruitfly (20-12-2008)
Old 22-12-2008, 7:03 PM   #13 (permalink)
fruitfly's Avatar
Just bought the last two on display at my local Comet. Man at store 'reminded' me that I needed HDMI cables, even though the player includes it's own cable and can also output via component. I wonder if he was going to direct me to the Monster cable aisle
My Collection
budget, dvd, upscaler
