3.5 million visitors each month
Go Back   AVForums.com > Home Entertainment Players and Recorders > Blu-ray and DVD Players > DVD Players
Latest popular product pricesPowered by
Panasonic DMR-EX769 160GB
Coby TFDVD7008
Samsung DVD-H1080
Panasonic DMR-EZ48
Coby TFDVD7008
Samsung DVD-H1080
Panasonic DMR-EZ48
LG DRT389H
Sony DVP-FX730
Panasonic DMR-XS350 250GB
Panasonic DMR-EX 89 400GB
Panasonic DMR-EX98V 250GB
Toshiba RD-XV59DT 250GB
 More...Prices updated March 13th at 5:30am and include delivery.
Thread Thread Starter Forum Replies Last Post
Multi-Region, Multi-Voltage DVd player needed, please help Taz69 DVD Players 0 13-02-2008 8:58 AM
Can you convert a region 1 dvd player in to a multi-region player? fatrich DVD Players 3 28-01-2004 3:33 PM
Region 1 discs played on multi region player jasper Movies and The Cinema 3 02-07-2001 6:04 PM
Old 08-12-2008, 4:25 PM   #1 (permalink)
multi-region DVD player?
Hello DVD expert type people!
I really need your help, I have an old panasonic s27 dvd player, which i assumed was multi-region because in the setup menu you can toggle between pal and NTSC... now Ive just bought a load of region one NFL DVDs from the states, thinking they would work on my player if I changed the output to NTSC.. sadly it just tells me disc is not compatible in your region...
now Im pretty sure that there is nothing I can do with this DVD player re. hacks having trawled the web for codes...
SO, my next plan is just to buy a new DVD player that is capable of playing region one DVDS that have enhanced regional coding or whatever it is (they are made by warner bros, and amazon said they use this extra security measure..)
Does anybody have any tips what DVD player to buy? Also I have a Sony kdl32v4000 LCD telly.. I am assuming this is compatible with NTSC discs (I read somewhere that some TVs wont support it?)
if anybody can help, or make any sense of the above ramblings, I would be most grateful...
thanks!
Ben
thebassmonkey is offline   Reply With Quote
Old 08-12-2008, 7:28 PM   #2 (permalink)
Thanks: Gave 1, Got 10
Re: multi-region DVD player?
Hi Ben
I don't think you will have any problems displaying an NTSC source on your Sony.
Hackable region free players start from about £15 (Asda cheapie). I have palyed with one of these and it plays all my region 1 discs. Spend more money and you should be able to improve on picture quality. Philips players are hackable from the remote so something like the DVP5980/5990 (£60)play Divx, mps etc and have an HDMI socket with upscaling to 1080p.
It all depends on how much you want to spend.
Growlerman is offline   Reply With Quote
Old 08-12-2008, 8:58 PM   #3 (permalink)
thanks for the reply growlerman... im looking to spend as little as poss (under £100), but i want something decent/reliable... will look into the philips.. im assuming that you cant buy out-of-the-box multi region DVD players? i noticed there used to be some pioneer ones on amazon, but they are no longer available...
cheers
Old 11-12-2008, 5:39 PM   #4 (permalink)
Thanks: Gave 0, Got 3
I've just bought this Sony Player and am impressed - £68 for multiregion out the box including delivery from Superfi.
SONY DVPNS708H DVD PLAYER (MULTI-REGION) - available from Superfi UK Visit http://www.superfi.co.uk/index.cfm/page/moreinfo.cfm/product_id/4263 for details
Its a nice player - available in black or silver.
I only have a handful of R1 discs but this plays them all including Spiderman which I am sure had the enhanced regional coding.
Sanyo Z3, Samsung DVD-HD850, Humax 9200t PVR, Sony HT-SL5 Amp. JVC AV28R Widescreen TV.
dmjohnson123 is offline   Reply With Quote
Old 12-12-2008, 5:38 PM   #5 (permalink)
cheers for the replies... i plumped for the philips player and it just arrived and the code has worked fine/dvds work fine.. happy days
Old 14-12-2008, 2:37 AM   #6 (permalink)
Thanks: Gave 34, Got 90
Do you need a code or something. as when I look at reviews elsewhere it states its not multi regional ?
Or is this one different.
Sony DVPNS708 DVD Player with 1080 Up-scaling - Black: Amazon.co.uk: Electronics & Photo
Canon 400D With Stock Lens.
Asus A8N-SLI Deluxe, AMD Athlon 64 3500+ (Venice Core), 2GB Corsair XMS Memory (2x1GB), Leadtek Geforce 7800GTX, Sound Blaster Audigy 2.
alphaomega16 is offline   Reply With Quote
Old 14-12-2008, 4:53 PM   #7 (permalink)
Some players need to multi-regioned either using a special remote or via a tweaked firmware upgrade. I don't think the Sony can be multi-regioned at home it needs to be done by the supplier prior to purchasing.
Superfi (and other suppliers if stated) do this multi-region upgrade for you with the Sony so it is multi-region when you receive it from them. So, if you want this player multi-region then purchase it from a supplier stating it is supplied multi-region.
Oh, and IMHO, its a good'un !
Old 15-12-2008, 6:42 PM   #8 (permalink)
Cheers for the clarification mate much appreciated.
I am looking for a new one since the YELO I had for years and still worked when I used it last has just gone poof. Can't find the bugger anywhere . I still have the remote for the YELO one but just cant find the damn thing lol.
Anyway back to the sony, any know where to find a pic that shows the remote as well
Old 16-12-2008, 8:38 AM   #9 (permalink)
The remote for the Sony 708 is shown in the manual if you want to check which buttons and layout it has - hope this link works, if not just go through the sony site to download the manual:
http://pdf.crse.com/manuals/3283151111.pdf
The remote is labeled RMT-D175p - I found this one on ebay:
Sony DVD Remote Control RMT-D175P (brand new) on eBay, also, DVD Remote Controls, DVD Home Cinema, Consumer Electronics (end time 21-Dec-08 04:48:06 GMT)
Old 16-12-2008, 3:27 PM   #10 (permalink)
Tyvm Kind Sir.
dvd, multiregion, player
Copyright © 2000-2010 M2N E. & O. E.
