AVForums.com twitter AVForums reviewers are ISF Certified.  Click for more information. AVForums is a member of CEDIA.
AVForums.com is the UK's biggest & best home consumer electronics discussion resource
Go Back   AVForums.com > Home Entertainment Players and Recorders > DVD Players
Notices
OPPO BluRay player v's Oppo 983 for DVD replay Cloth-Ears Blu-ray Players 35 06-11-2008 3:07 PM
Oppo 983 - so much better than Oppo 981 on a 32" LCD? skal1971 DVD Players 6 11-08-2008 1:38 PM
New OPPO 980 mbalari DVD Players 2 26-07-2007 3:59 PM
Oppo 981. Derwentrocker DVD Players 19 07-12-2006 7:00 AM
Oppo 971 - Picture corruption - Oppo Bad - Xbox 360 good! TheBlueRaja DVD Players 13 30-09-2006 5:24 PM
Old 01-12-2008, 3:15 PM   #1 (permalink)
Thanks: Gave 10, Got 7
Oppo 981 (£115) or Oppo 980 (£169)
Been looking at DVD players and decided to take the plunge and order a Oppo 980 (after returning a Pioneer 600AV which was very noisy) from CRT projectors to compliment my Pioneer 4280. I don't have any external amps/sound system at present (although looking) and intend the Pioneer 4280 do the upscaling using the HDMI cable.
The Oppo 981 has been reduced to £115, compared to the Oppo 980 £169. So my question is would the 981 be a better option or am I better to stick with the 980? Also looking at the model comparision chart for the DVD player does the 981 output @ 576p using the HDMI cable? (From what I have read it better to let the DVD player deinterlace (576i to 576p) and let the Pioneer upscale to 720p (Correct me if i am wrong)).
Or if I purchased the 981 and used 720p would i really notice much difference in PQ quality.
James
Jixes is offline   Reply With Quote
Old 01-12-2008, 4:11 PM   #2 (permalink)
pete_21's Avatar
Thanks: Gave 73, Got 162
Re: Oppo 981 (£115) or Oppo 980 (£169)
I own an Oppo 981HD and have it set to 720P via HDMI.Picture quality is very good (especially for a £115 player).Its better then my Panasonic BD-30 Blu Ray player (for DVD playback obviously),hence the reason I'm still using it.The player can display 576P via HDMI but on my set (Panasonic TH37PX80) I found the picture looked best upscaled by the player to 720P.Remote on the 981 is a bit rubbish and the screensaver looks like a ZX Spectrum but other than that I would recommend these players for sure,in fact I've just ordered another one for my friend.For AV quality its a seriously impressive piece of kit for its price and I'm very pleased with mine.Hope this helps.
pete_21 is offline   Reply With Quote
Jixes (05-12-2008)
Old 01-12-2008, 4:19 PM   #3 (permalink)
Eminent Member
kingfats's Avatar
Thanks: Gave 1,091, Got 7,124
s
Hi mate.
576p/720p/1080i/p with the 981 over HDMI.
Threre's no hard and fast rule to be honest,but i would definitely give 576p a go and see what you think.
All the best.
Pioneer KRP-600M, Onkyo 876, M&K LCR 750, M&K M4T, SVS PC13 Ultra PS3, Oppo 983, LX91, S5000ES ,Oppo BDP-83, XE1, Logitech 1000 remote, wildlife pond in back garden.
Be a man.........make a compost heap!
kingfats is offline   Reply With Quote
Old 01-12-2008, 5:33 PM   #4 (permalink)
pixphipau's Avatar
Thanks: Gave 264, Got 31
I have a 981 AND 983, forr £115 squid the 981 is a VERY good option, IMHO.
pixphipau is offline   Reply With Quote
Old 05-12-2008, 11:03 AM   #5 (permalink)
Thanks for all the advice. I have just ordered a Oppo 981 for £115 from CRT Projectors. At that price it seems very good value compared to the 980 model at £169.
Is there any advice on the configuration settings (like there is for the Pioneer 4280 on this site(Thanks to Bumtious)) or is it a case of trial and error?
James
Old 05-12-2008, 11:21 AM   #6 (permalink)
Eminent Member
kingfats's Avatar
James
Hi Jixes.
It is case of test and see really 576p might look be best to you or then again it might not.
Cheers.
Jixes (05-12-2008)
980, 981, oppo, £115, £169
