help setting up audio denon 1740
Hi there
I have managed to sort out my amp denon 1907 at long last and with a lot of help from you guys
Now trying to sort out the setting on the dvd i have it connected to tv with HDMI cable and an optical cable to the amp.
Can some one help me i have the following to adjust in the audio setting
DRC on or off
LPCM on or off
Doly ditial pcm or bitstream
DTS off or bitstream
MPEG Pcm or bistream
AUDO mode HDMI or analog
What options should i use the amp has its own decoder i think but the instruciton manual makes no sense to a novice just want the best sound out of the amp
Also on the display options i have the following
video out - scart/ component interlace or component progressive
prog mode - auto 1 or auto 2 or video
HDMI select YCBCR or HDMI
HDMI picture Normal orenhanced
Any pointers on this as well
Lots of questions hopefully there is help out there
cheers
