Go Back   AVForums.com > Home Entertainment Players and Recorders > Blu-ray and DVD Players > DVD Players
Today's price checkPowered by
Panasonic DMR-EX769 160GB
LG DRT389H
Sony DVP-FX730
LG RHT497H 160GB
LG DRT389H
Sony DVP-FX730
LG RHT497H 160GB
Panasonic DMR-EX98V 250GB
Philips DVP3310
Panasonic DMR-EX79 250GB
Samsung DVD-H1080
Sony RDR-HXD995
Panasonic DMR-XS350 250GB
 More...Prices updated November 22nd at 7:30pm and include delivery.
Old 01-06-2003, 12:05 AM   #1 (permalink)
Philips DVDR880
Can some one help me please.
My dvd recorder will not play video cds. Been through the manual and on screen menus. Tried philips' web site etc still no luck. I get sound but no picture, the machine seems to play it as if it were an ordinary cd/mp3 disc.
All help greatly appreciated
Regards
Jiz
jizm is offline   Reply With Quote
Old 01-06-2003, 12:32 AM   #2 (permalink)
TommyVecetti's Avatar
Thanks: Gave 83, Got 89
www.dvdplusrw.org
They should be able to help more in depth.
TommyVecetti is offline   Reply With Quote
Old 01-06-2003, 12:38 AM   #3 (permalink)
Rasczak's Avatar
Thanks: Gave 489, Got 631
Are these VCDs you've compiled yourself or 'official' ones. If the former make sure you've encoded the files within the specifications listed in your manual. You can use a programme like TMPG Encoder to re-encode if necessary.
Rasczak is offline   Reply With Quote
Old 01-06-2003, 2:04 AM   #4 (permalink)
Done for me by some-one else. It's old home videos/cine film compiled on to a disc and set to music.
Old 01-06-2003, 2:14 AM   #5 (permalink)
Rasczak's Avatar
I suggest firstly you try them on your PC - do the files play OK in Windows Media Player? Assuming they do work (otherwise the problem is more complicated) then download a version of TMPG Encoder (a quick look suggest that http://www.digital-digest.com/dvd/do...s/tmpgenc.html may point you in the right direction). Then use the Project Wizard to re-encode the files in either NTSC or PAL. Then reburn (preferrably using an appropriate wizard in a programme like Nero 5.5) the project to a 80 minute CD-R - this will automatically create the file structure for a VCD.
It's probably violation of one of the above that is the reason for it not playing. If you do all this then you should be able to get it in a playable form.
You may want to check out:
http://forum.digital-digest.com/
They have several forums devoted to VCD so you may find it more helpful to get specific advice there.
Old 01-06-2003, 2:18 AM   #6 (permalink)
The disc plays fine on a friends Philips DVD-R 1000. This suggests that the disc is fine and is probably a set up problem on the machine?
Old 01-06-2003, 2:26 AM   #7 (permalink)
Rasczak's Avatar
Yes and no. Obviously the disc is fully functional but the Philips DVDR-1000 is a high-end machine whereas the Philips 880 isn't. Therefore the range of media that can be used in the 1000 may well be greater than the 880. Re-encoding as described above may resove the problem. HOWEVER given this new information I would suggest, as you guess, exploring the setup options first. You'll need an 880 user to help you there. Given the 880s track record it could also be an error/out of date firmware. To explore these avenues I would suggest going to the forums TommyVecetti pointed you to.
Old 01-06-2003, 2:31 AM   #8 (permalink)
Thanks for that wil take an in depth look at the site reccomended. On another note I just noticed you are in Southampton, little bit freaky as I am in Eastleigh. Small world!!!
dvdr880, philips
