Go Back   AVForums.com > Home Entertainment Players and Recorders > Blu-ray and DVD Players > DVD Players
Today's price checkPowered by
Panasonic DMR-EX769 160GB
Sony DVP-FX730
LG DRT389H
Philips DVP3310
Sony DVP-FX730
LG DRT389H
Philips DVP3310
Panasonic DMR-EX79 250GB
LG RHT497H 160GB
Panasonic DMR-EX98V 250GB
Samsung DVD-H1080
Panasonic DMR-XS350 250GB
Sony RDR-HXD995
 More...Prices updated November 21st at 2:30pm and include delivery.
AV Receiver: what is a good budget receiver that is cheaper than Denon AVR-1507? Osamede AV Amplifiers and Receivers 12 25-09-2009 10:42 AM
DVD and Receiver - Space constraints sma1001 Custom Installations and Installers 1 25-04-2008 3:23 PM
Arsenal TV not on Virgin due to Capacity Constraints KevinPedrick Virgin Media 31 24-03-2008 1:47 PM
Micro System with dimensional constraints... timfg Hi Fi Systems and Separates 3 13-02-2008 12:23 AM
What AV receiver to get to fit a restricted space? Sanders79 AV Amplifiers and Receivers 20 08-11-2006 5:34 PM
Old 25-04-2008, 8:57 AM   #1 (permalink)
Thanks: Gave 1, Got 0
I was all set to buy a DVD receiver when i was advised that its better to split the DVD and receiver because the DVD tends to "go first" possibly leading to the whole unit being replaced.
My issue is space. I only have two "holes" in the unit which are sized:
(HWD) - 140x310x490
(HWD) - 140x480x490
So there are two constraints: (1) the width of one unit - no wider than 31cm (2) the height of both - no higher than 14cm. The second of these appears to constrain the receiver choice.
I expect it's harder to get a narrow receiver so assume that slot should go to the DVD.
I'd like the DVD player to feed out through HDMI and to upscale to 1080p (if poss) and to play audio CDs. Main use here is as home cinema.
The main use will be to link to the TV (Full HD Panasonic plasma) and the speakers (starting with a 2.1 q acoustics compact set - 1010i and 1000s).
I also have Sky HD which i'd like to link to the receiver/speakers. That takes up the other slot in the unit.
Any suggestions?
For info i had been about to go for the Onkyo DR-s501 (DVD receiver) until the guy in the shop suggested i should separate the DVD player.
sma1001 is offline   Reply With Quote
constraints, dvd, receiver, space
