Go Back   AVForums.com > Home Entertainment Players and Recorders > Blu-ray and DVD Players > DVD Players
Today's price checkPowered by
Sony DVP-FX730
LG DRT389H
Panasonic DMR-EX769 160GB
LG RHT497H 160GB
Sony DVP-FX730
LG DRT389H
LG RHT497H 160GB
Philips DVP3310
Panasonic DMR-EX98V 250GB
Panasonic DMR-EX79 250GB
Samsung DVD-H1080
Panasonic DMR-XS350 250GB
Sony RDR-HXD995
 More...Prices updated November 21st at 9:30pm and include delivery.
DVD player with DiVX upscaling bhure@usa.com DVD Players 7 05-03-2007 7:10 PM
DVD upscaling + DivX player ? ThreeDee DVD Players 9 22-12-2006 12:59 PM
Best HDMI DIVX upscaling dvd player with USB for about £150 johndoe1 DVD Players 0 10-10-2006 11:25 AM
Upscaling DivX DVD player NL7 DVD Players 6 14-04-2006 6:22 PM
DivX and Upscaling on one player? dr_mabuse DVD Players 8 19-10-2005 9:27 PM
Old 23-04-2008, 10:22 AM   #1 (permalink)
Thanks: Gave 5, Got 0
Dvd/divx Upscaling Player Advice For A Newbie
Hi all
I intend to buy a new dvd player soon.
I would like it to
a) upscale to 1080p as i have a 1080p TV.
I don't know if there's much difference between between 1080p and
1080i given my viewing distance of about 12 feet from a 40 inch TV-if not I would consider a 1080 i upscaler
b) play divx/avi -crucial as i watch a lot of divx/avi films.
with subtitle support if possible
c) decode DTS and DD - dont know if this is necessary as my amp decodes
this type of sound.
d) have both optical and digital coaxial outputs - or at least optical.
e)support Bravia Sync which, I think, lets me use one remote for my TV and
DVD player - but this is not crucial.
f) be black as this would blend in with my TV and surround sound system -
this is not crucial as i could live with silver.
My current set up is a SONY 40 inch bravia TV (KDL40D3500) and a Sony HTSF 1100 speaker and amp package.
My budget is about £80.
I would appreciate any advice.
Terry H
terry h is offline   Reply With Quote
Old 23-04-2008, 3:08 PM   #2 (permalink)
Infiltraitor's Avatar
Thanks: Gave 9, Got 14
Re: Dvd/divx Upscaling Player Advice For A Newbie
How about the DVP-NS78?
It doesn't have optical out, but does have a co-axial output and would appear to tick most of your boxes there, including 1080p.
I'm running one on my 32" Sony (1080i), and the picture quality is superb from SD disks.
The black version is currently £71.70 inc on Amazon.
Infiltraitor is offline   Reply With Quote
Old 23-04-2008, 6:39 PM   #3 (permalink)
Infiltraitor
Thanks for this suggestion . I've had a look at the reviews on Amazon which are very favourable with regard to upscaling the only downside is that a few reviewers have had problems with Divx playback with the DVP-NS78 which is putting me off as I have quite a few DIVX movies.
Can anyone let me know of there experience with DIVX playback with the
DVP-NS78 or suggest another model that is not tempremental with DIVX.
Old 24-04-2008, 6:47 AM   #4 (permalink)
chris57's Avatar
Thanks: Gave 4, Got 154
The best player for divx Ive had was my Phillips 5960. There is a newer 1080p version the 5980. If you predominately use divx/avi then the Phillips if you use DVD then the Sony would be the way I would go.
The French are the leaders in terms of dvix demands from customers and the available player. Have a look here:-
http://www.divx-compare.com/section-...r-dvd-divx.htm
Peekton are an excellent make if you can find one in the UK:-
http://www.divx-compare.com/lecteur-...K6750-HDMI.htm
Have a look here for divx compatability:-
http://divxtest.surdvd.com/sommaire.php3?lang=en
Sony KDL26S2030U, Popcornhour A100/A110 Network Media Tanks, Phillips DVP-5960, Peekton 6006, Yamada 6700, PS3, Harmony 688
chris57 is offline   Reply With Quote
advice, dvd or divx, newbie, player, upscaling
