Go Back   AVForums.com > Home Entertainment Players and Recorders > Blu-ray and DVD Players > DVD Players
Today's price checkPowered by
Panasonic DMR-EX769 160GB
LG DRT389H
Sony DVP-FX730
LG RHT497H 160GB
LG DRT389H
Sony DVP-FX730
LG RHT497H 160GB
Panasonic DMR-EX98V 250GB
Philips DVP3310
Panasonic DMR-EX79 250GB
Samsung DVD-H1080
Panasonic DMR-XS350 250GB
Panasonic DMR-EZ48
 More...Prices updated November 23rd at 12:30am and include delivery.
Old 16-03-2003, 9:09 PM   #1 (permalink)
adam*B
Posts: n/a
Differences in S-vid and DV ?
Does anyone know the difference in picture quality between S-Vid and Digital ? I want to buy a DVD recorder to archive my camcorder footage. My camcorder has DV out so it would be possible to hook it up to a DVD recorder that has DV in...but looking at the players available means spending more.
If I go for say the Panasonic E-50 that has S-Vid in and want to send on the footage via DVD-R to friends etc will I notice a massive difference in Digital quality over S-Vid on a normal size TV?
Thanks in advance...
Old 16-03-2003, 9:46 PM   #2 (permalink)
Thanks: Gave 0, Got 44
I think the philips 890 has dv in for your camcorder , is it more expensive than the e-30 or is the e-30 better for editing?
evans is offline   Reply With Quote
Old 16-03-2003, 10:07 PM   #3 (permalink)
TommyVecetti's Avatar
Thanks: Gave 83, Got 89
Re: Differences in S-vid and DV ?
Originally posted by adam*B
To be honest, no you wont notice any great difference at all. And I say that as someone who works and edits a lot of DV footage.
It would only really be necessary on a proffesional duplication level, not for recording home movies onto DVD for others to view. The quality will still be first rate.
Either way you look at it, your footage is still going onto an Mpeg 2 compressed DVD. And I think you'd be lot happier with the recording options available to you on the Panasonic models.
TommyVecetti is offline   Reply With Quote
differences, svid
