Go Back   AVForums.com > Home Entertainment Players and Recorders > Blu-ray and DVD Players > DVD Players
Today's price checkPowered by
LG DRT389H
Sony DVP-FX730
Panasonic DMR-EX769 160GB
LG RHT497H 160GB
LG DRT389H
Sony DVP-FX730
LG RHT497H 160GB
Philips DVP3310
Panasonic DMR-EX98V 250GB
Panasonic DMR-EX79 250GB
Panasonic DMR-XS350 250GB
Samsung DVD-H1080
Panasonic DMR-EZ48
 More...Prices updated November 23rd at 8:30pm and include delivery.
Old 14-10-2007, 4:49 PM   #1 (permalink)
Thanks: Gave 48, Got 16
Problem playing XVid files on Sammy 850
Only noticed this recently, wondering if it's the player or the files...
Whenever I play an XVid file that's not the correct aspect the DVD player ( TV is set to 16:9 so I don't think it's this) stretches the image to fill the screen - i.e. I dont get any black bars so the image is stretched vertically which looks horrible
Is this the player at fault? Or something I can rectify with the file itself? Have tried connecting via HDMI, component and SCART and it behaves the same way.
Thanks!
Adam
Panasonic TH42PV500 - PS3 - Wii - MacBook Pro - Nikon D80 - AppleTV - iPhone 3G
Monty1977 is offline   Reply With Quote
Old 14-10-2007, 5:29 PM   #2 (permalink)
Thanks: Gave 24, Got 630
Re: Problem playing XVid files on Sammy 850
the workaround on some files is set the dvd as 4:3 and then use zoom on the tv. it's annoying to do that but it works
My opinions are my own and not necessarily those held by the AVForums or anyone else.
unique is offline   Reply With Quote
Monty1977 (14-10-2007)
Old 14-10-2007, 6:18 PM   #3 (permalink)
Thanks, that's an extremely useful tip for the files I've already burned to disc - playing around with Virtual dub I've figured out how to add the bars to a file but it means re-encoding the entire file, not fun!
Cheers,
adam
Old 14-10-2007, 9:03 PM   #4 (permalink)
Cheers,
adam
i have the 950 which also has sacd and dvda playback, but i replaced it with a pioneer 696 as my main player as there were so many niggles with the sammy, and the divx support was part of it. it's a pain if you have lots of little clips in different aspect ratios. i just use the 950 as a second player in the bedroom now, and xboxes for divx/xvid
Old 15-10-2007, 8:23 AM   #5 (permalink)
So is the 696 any better in this respect? Will it pad the picture with boxes depending on the resolution of the file?
Thanks!
Adam
Old 15-10-2007, 12:36 PM   #6 (permalink)
Thanks!
Adam
if you have a widescreen tv, and play back a disc full of avi files in different aspect ratio's, it usually plays them back correctly. thus black bars at the sides of 4:3 material. i think some don't, but thats the way people create them i think (ie. old files).
they don't make the 696 anymore, it was replaced by a newer model, the DV600, which is reviewed at the following thread
Pioneer DV600 - Are there any online reviews?
there is another slightly cheaper model without sacd/dvda support, i think it's DV400
850, files, playing, problem, sammy, xvid
