Go Back   AVForums.com > Home Entertainment Players and Recorders > Blu-ray and DVD Players > DVD Players
Today's price checkPowered by
Sony DVP-FX730
LG DRT389H
Panasonic DMR-EX769 160GB
LG RHT497H 160GB
Sony DVP-FX730
LG DRT389H
LG RHT497H 160GB
Philips DVP3310
Panasonic DMR-EX98V 250GB
Panasonic DMR-EX79 250GB
Samsung DVD-H1080
Panasonic DMR-XS350 250GB
Sony RDR-HXD995
 More...Prices updated November 22nd at 6:30am and include delivery.
Old 14-10-2007, 10:03 AM   #1 (permalink)
Thanks: Gave 3, Got 2
Multiregion & R.C.E Question
Hi All
First Question
Is it worth getting a Multiregion Player?
What are the benefits?
Second Question
Does it matter whether the player is Region 1 via a handset code,or Chipped internally,do they still both play all region 1 discs?
Alan
asimmd is offline   Reply With Quote
Old 14-10-2007, 1:32 PM   #2 (permalink)
Thanks: Gave 24, Got 629
Re: Multiregion & R.C.E Question
the benefits of a multiregion player are that you can play any dvd from anywhere in the world, thus you can order region 1 american imported discs for example, sometimes you can get films before they are released on dvd in the uk, and sometimes you can get cheaper imports. sometimes both cheaper and quicker, plus there are titles available in other countries but not the uk
generally it doesn't make a big difference as to the method used to make multi region. i don't think many players need to be chipped these days, it's either handset hack (which is arguably the best as it's easy to change region again, and thus set to R1 to allow RCE discs, isntead of R0 for multiregion) or firmware update (you can sometimes download these online and burn to a cd then insert in the player to update)
i think most players available now can be made multiregion one way or another. it's worth checking to see if the model you want can do it before choosing the player. your existing player may even be made mutliregion (google up the model and see)
My opinions are my own and not necessarily those held by the AVForums or anyone else.
unique is offline   Reply With Quote
Old 14-10-2007, 4:32 PM   #3 (permalink)
Many thanks for the reply.
I googled for a code but I forgot my model is a Panasonic DMR-E85 which is a recorder,but I got nowhere anyway.
I think I will need to replace it anyway,but it would have been nice to find a code,just to test the water.
Alan
Old 14-10-2007, 5:36 PM   #4 (permalink)
Alan
from checking another site, i found only this
[FONT=Verdana]Panasonic generic regional code IR sequence
0082 0015 0089 0004 00F2 0033 0017 0010 0091 0013
You can enter these codes with a PocketPC using TV Remote Controller and making a CCF file with these codes. Or use a Palm with Omniremote. Make sure no disc in the player when entering this code.
so it can be made MR but you have to use a PDA to send the instruction via infra red. maybe a friend can do it for you if you are unsure and/or don't have a suitable PDA
[/FONT]
multiregion, question, rce
