3.5 million visitors each month
Go Back   AVForums.com > Home Entertainment Players and Recorders > Blu-ray and DVD Players > DVD Players
Latest popular product pricesPowered by
Panasonic DMR-EX769 160GB
Samsung DVD-H1080
LG DRT389H
Sony DVP-FX730
Samsung DVD-H1080
LG DRT389H
Sony DVP-FX730
Panasonic DMR-EZ48
Coby TFDVD7008
Panasonic DMR-XS350 250GB
Toshiba RD-XV59DT 250GB
Panasonic DMR-EX 89 400GB
LG RHT497H 160GB
 More...Prices updated March 10th at 6:30am and include delivery.
Old 03-09-2007, 8:49 PM   #1 (permalink)
Thanks: Gave 86, Got 24
Hdmi dvd for under £40
Does anyone know of any delas for a sub £40 hdmi dvd player.
I want one to fit into a wall cavity that i have so it will be a perinant fixture in the wall.
I know asda and aldi have cheapies but im worried about the lastabilty of such models.
Anyone know of any well known brands that have a budget model?
Louis
Front Room - Panasonic TXP50G10, Yamaha Ysp -1100, Sky Hd, Xbox 360 elite, Sony Bdp s350 blu ray, P-1000 Sub Kitchen DinerPanasonic 32 LXD60 wall mounted BedroomApple iMac 27"
louisg is offline   Reply With Quote
Old 03-09-2007, 9:19 PM   #2 (permalink)
Thanks: Gave 9, Got 10
Re: Hdmi dvd for under £40
i know it is over your budget at £50 but have a look at this one from play
Samsung PS42Q96HDX, Humax 9200T(B), Sky+, Nintendo DSi, Playstation 3 PSN bluechang, Xbox360 dadoftriplets AMD IIx 2 240, 2GB Ram, 580GB HDD, Win7 32bit.
lovethechang is offline   Reply With Quote
Old 04-09-2007, 6:18 PM   #3 (permalink)
take a look at
http://www.bigpockets.co.uk/product....roduct=PLA0040
no idea what it is like
whiz_bit is offline   Reply With Quote
Old 05-09-2007, 3:46 PM   #4 (permalink)
i will take a look at that one.
sumavision isnt a very good brand so will steer clear of that one.
louis
Old 06-09-2007, 10:29 AM   #5 (permalink)
chris57's Avatar
Thanks: Gave 4, Got 155
Get yourself a 5960 Phillips. They are around at that price. Try Richer Sounds or Amazon.
NMT Forum Moderator
Sony KDL26S2030U, PCH A100/A200/C200 NMT, Phillips DVP-5960/Peekton 6006/Yamada 6700, PS3, Harmony 688
chris57 is offline   Reply With Quote
Old 06-09-2007, 10:31 AM   #6 (permalink)
Yes, see below- Tevion 34.99 from Aldi- bargain with loads of features.
jimbojones22 is offline   Reply With Quote
Old 06-09-2007, 10:48 AM   #7 (permalink)
Richer sounds do that model for £69.95
Amazon have it brand new for £39.99
Might just buy one for myself at that price - chris57 do you have this one yourself? Is it a decent dvd player?
Old 06-09-2007, 11:01 AM   #8 (permalink)
Thanks: Gave 15, Got 45
Richer sounds do that model for £69.95 - thats the 5980 model
Amazon sell the 5980 for - £55.52
its the 5960 that Amazon sell for £40
Tafsir is offline   Reply With Quote
Old 06-09-2007, 11:39 AM   #9 (permalink)
Thanks: Gave 1, Got 0
is this the best value? do any upscalers also have recorders on them?
sven365 is offline   Reply With Quote
Old 07-09-2007, 7:32 AM   #10 (permalink)
chris57's Avatar
Yes I do have one myself. Over the years since divx budget players arrived ive owned quite a few different ones aswell. The Phillips is great value and in my opinion produces a better quality picture than others. It also accepts more avi/xvid/divx formats than others. The 5960 has modded firmwares available than bring extra features with it and also packed bitstream support (if you can face losing multichannel output via coaxial simultanously with HDMI).
NMT Forum Moderator
Old 07-09-2007, 7:39 AM   #11 (permalink)
Thanks: Gave 47, Got 15
I know there are slightly cheaper ways to buy online but the best shops to get the PHILIPS 5960 from are ARGOS or ASDA at £49.99 great player, I just got mine yesterday
Sony 40" Bravia LCD KDL40D3500 * Nokia N95 8GB * T810 Dual PVR * Philips DVR5960 * Virgin Cable * LG DVX392H
radical1 is offline   Reply With Quote
Old 08-09-2007, 3:19 PM   #12 (permalink)
looksm like a philips it is then.
thanks for info
Louis
dvd, hdmi, £40
Copyright © 2000-2010 M2N E. & O. E.
