Go Back   AVForums.com > Home Entertainment Players and Recorders > Blu-ray and DVD Players > DVD Players
Today's price checkPowered by
Panasonic DMR-EX769 160GB
LG DRT389H
Sony DVP-FX730
LG RHT497H 160GB
LG DRT389H
Sony DVP-FX730
LG RHT497H 160GB
Panasonic DMR-EX98V 250GB
Philips DVP3310
Panasonic DMR-EX79 250GB
Samsung DVD-H1080
Panasonic DMR-XS350 250GB
Panasonic DMR-EZ48
 More...Prices updated November 23rd at 2:30pm and include delivery.
Old 31-08-2007, 10:18 PM   #1 (permalink)
DougieB's Avatar
Thanks: Gave 5, Got 10
Samsung DVD HD860 Switching Off
Hi All
Curious fault has suddenly appeared when using this player via HDMI on Samsung LE32R41BD LCD. Disc loads and begins playback then approx 1 min
into movie proper the 860 just switches off. Restarting and letting it carry on the second time , the DVD plays through to the end. This has happened three times now, with The Incredibles (R2), Sunshine (R2) and The Abyss (R1).
Any help appreciated.
DougieB
AV: LG 32LH3000, Sony BDP-S350 Blu-ray,
Panasonic DMR-ES20DEB Video Recorder, Samsung S2100 Cable,Yamaha P110 Speaker System, Pioneer VSX 915 AV Receiver.HTPC: AMD Phenom II 550BE(Callisto)@3.6Ghz, XBox 360 + HD-DVD Drive.
DougieB is offline   Reply With Quote
Old 02-09-2007, 3:52 PM   #2 (permalink)
Thanks: Gave 2, Got 0
Re: Samsung DVD HD860 Switching Off
Hi, I'm having almost the same issue.
Did you find a solution ?
The HD860 just goes into standby mode at apparently random times. Sometimes it is ok for an hour or longer. Sometimes it fails after a few seconds. I've tried many different discs and power points. Even just playing a DVD in the garage with nothing attached: you can see from the playing clock that it stops after a few mins.
Also the BRIGHT blue light. Any option to cut that out ?
regards
LegendsWear7 is offline   Reply With Quote
Old 02-09-2007, 6:00 PM   #3 (permalink)
Peopleselbowpad's Avatar
Thanks: Gave 37, Got 37
Could be a faulty Power Board. I'd get it replaced if you can.
Peopleselbowpad is offline   Reply With Quote
Old 02-09-2007, 6:19 PM   #4 (permalink)
DougieB's Avatar
Exclamation Re: Samsung DVD HD860 Switching Off
regards
Hi LegendsWear7
No I have not yet found a solution, but I am going to try the firmware update
and see if that corrects the problem (fingers crossed the M/R hack will still work)
Will post results later. Firmware upgrade can be found here:http://tech.groups.yahoo.com/group/ZoranDVD/
DougieB
Old 18-09-2007, 6:19 PM   #5 (permalink)
DougieB's Avatar
Hi to any 860 owners.
Tried updating firmware on 860 but found that the posted update on the Samsung site was the same as currently on my player (081006.05 86iHVXEXEL).
Am still getting the interruptions to playback at various points. Has anyone come across a solution via Firmware updates or other means??
DougieB
dvd, hd860, samsung, switching
