Go Back   AVForums.com > Home Entertainment Players and Recorders > Blu-ray and DVD Players > DVD Players
Today's price checkPowered by
Sony DVP-FX730
LG DRT389H
Panasonic DMR-EX769 160GB
LG RHT497H 160GB
Sony DVP-FX730
LG DRT389H
LG RHT497H 160GB
Philips DVP3310
Panasonic DMR-EX98V 250GB
Panasonic DMR-EX79 250GB
Samsung DVD-H1080
Panasonic DMR-XS350 250GB
Sony RDR-HXD995
 More...Prices updated November 22nd at 12:30pm and include delivery.
Old 31-08-2007, 2:42 PM   #1 (permalink)
A hello and a question
First of all may I say hello and how good it is to find so many fellow technoracks.
It look like I have a lot of reading to do.
My question, (if I may ask one so early in our relationship?).
If I use an Upscaling dvd such as the Philips DVP5960 or the Aldi 39 quid job is it only the dvd information that gets upscaled and sent through HDMI or.......
Will it display an inputed scart composite / RGB signal by way of passthrough to the HDMI, and also upscale it, (or with the philips at least help a bit with progressive scan).
I have just purchased a Philips 42" Plasma with HDMI and the Composite signal from my Telewest Cable unit is quite Poo, I will change to the TV Drive next year, but I am not shure I could face Christmas tv watching painting by numbers..
Thanks for feeding my brain
Technowobble....
Technowobble is offline   Reply With Quote
Old 31-08-2007, 2:53 PM   #2 (permalink)
Thanks: Gave 16, Got 146
Re: A hello and a question
Its only the DVD that will get up scaled!
If you want to improve your Telewest box then plug it into your TV via scart and set the output to RGB. That should help!
Para is offline   Reply With Quote
Old 31-08-2007, 3:22 PM   #3 (permalink)
Ah!, Now then.....
I forgot to include that in my post.
I already use the scart connection from the box into the correct RGB scart on the tv, and the output from the box is set to RGB. I have also tried another scart cable and things are the same.
when I run a standard X box to said scart input the picture is great.
Even though the dvd would not upscale the analogue signal can it still be carried from the scart to the HDMI out into the telly (passing through) for some improvement.
I have have heard about various products that can take a composite signal and upscale to 720p to HDMI. I know that it might sound tight, but can I do this cheaply?.
Someone has also told me that if I run RGB Scart into an Eversham HDMI iBox it will upscale the signal?.
Technowobble
question
