Go Back   AVForums.com > Home Entertainment Players and Recorders > Blu-ray and DVD Players > DVD Players
Today's price checkPowered by
Panasonic DMR-EX769 160GB
LG DRT389H
Sony DVP-FX730
LG RHT497H 160GB
LG DRT389H
Sony DVP-FX730
LG RHT497H 160GB
Panasonic DMR-EX98V 250GB
Philips DVP3310
Panasonic DMR-EX79 250GB
Samsung DVD-H1080
Sony RDR-HXD995
Panasonic DMR-XS350 250GB
 More...Prices updated November 22nd at 9:30pm and include delivery.
Old 05-05-2007, 7:44 AM   #1 (permalink)
"Rolling" picture
Hi. I have a Pioneer DV-490V which is connected to my Panny TX-32LXD 500 via HDMI. When I switch the player on the picture rolls! As you can imagine, it is impossible to watch I have taken the player back to the shop I bought it from and explained the problem. And you guessed it, the guy in the shop could not find anything wrong with it! I do have to say that this is an intermittent fault which is doubly annoying because I never know what it is going to do Has anyone come across this before? If so, how did you solve it?
Viola is offline   Reply With Quote
Old 05-05-2007, 9:25 AM   #2 (permalink)
Thanks: Gave 15, Got 17
Re: "Rolling" picture
Hi, have you tried a different hdmi lead ?did they use your lead at the shop or their own ?
Regards Martin
tv: panasonic TX-P50X10, DVD Player: Sony dvp-ns92 ,Blu-Ray player: panasonic EB60 H.C. Amp: Sony STR-db790, Sky Box : panasonic, Freeview box : Sony VTX800, Speakers:Front : AE Evo 3, Centre : AE Evo, Rear : Eltax HT2 Bi-Polars, Subwoofer : Eltax Liberty,
pdbmjb is offline   Reply With Quote
Old 05-05-2007, 4:28 PM   #3 (permalink)
Hi Martin.
The guy in the shop used his own lead. And no, I haven't tried a different HDMI lead. With a brand new lead, it didn't occur to me that it may be faulty. Is that your thinking?
Regards, Piero
Old 06-05-2007, 12:23 PM   #4 (permalink)
Hkan's Avatar
Thanks: Gave 2, Got 50
Does this happens everytime you start the player?
Pioneer FAQ
Hkan is offline   Reply With Quote
Old 06-05-2007, 2:10 PM   #5 (permalink)
Hi. Yes it does.
Old 07-05-2007, 9:54 AM   #6 (permalink)
Hkan's Avatar
OK, What resolution do you have it set to? you should connect an S-video cable to change the resolution and perhaps to change what TV system your dvd player is set to too.
I have found out that this only accurse when you have played a dvd in NTSC format on a PAL TV. Then the player and the TV starts to fight over what system to use, this will result in the ''rolling'' picture. But only if you have the player set to output 720P or 1080i, are you using 720P?
Pioneer FAQ
picture, rolling
