Go Back   AVForums.com > Home Entertainment Players and Recorders > Blu-ray and DVD Players > DVD Players
Today's price checkPowered by
Panasonic DMR-EX769 160GB
LG DRT389H
Sony DVP-FX730
LG RHT497H 160GB
LG DRT389H
Sony DVP-FX730
LG RHT497H 160GB
Panasonic DMR-EX98V 250GB
Philips DVP3310
Panasonic DMR-EX79 250GB
Samsung DVD-H1080
Panasonic DMR-XS350 250GB
Panasonic DMR-EZ48
 More...Prices updated November 23rd at 12:30am and include delivery.
Old 04-05-2007, 10:28 PM   #1 (permalink)
upscaling DVD upto £60 ish to go with technosonic lcd
hi,
looking for an upscaling DVD player (budget upto £60 ish) to go with technosonic lcd 32"((black woolworths) then later on this year a 40/42" better quality tv.
have a xbox 360 hooked up at the moment - i take it an upscaling dvd player will be an improvement?
any ideas/deals/tips would be great
dmg123 is offline   Reply With Quote
Old 06-05-2007, 12:06 AM   #2 (permalink)
Thanks: Gave 25, Got 17
Re: upscaling DVD upto £60 ish to go with technosonic lcd
I have a xbox 360, and have owned a cheap Phillips upscaling player. From my and experience, and considering your budget, I wouldn't bother 'upgrading'. If you only spending £60, you can be sure the upscaling is going to be a complete waste of time. Although the 360 dvd playback isn't great, pq won't be much better with a ultra cheap dvd player. Budget players are fine with small tv's, but when connected to 40 inch screens or larger, they really do begin to look poor. If you are going to upgrade, my advice is to spend a little bit more on a deck to partner your future 40/42 inch screen. I use a Harman Kardon DVD 22 player, it wasn't cheap and it doesn't upscale, but the picture quality is way better than the £70 Philips I took back.
JENeric is offline   Reply With Quote
Old 08-05-2007, 12:49 PM   #3 (permalink)
metalguru's Avatar
Thanks: Gave 0, Got 2
Connect the xbox 360 to your tv with the vga connection it will now upscale sd dvd's and on my hd tv they look great.
metalguru is offline   Reply With Quote
Old 08-05-2007, 1:27 PM   #4 (permalink)
Dr Zaius's Avatar
Thanks: Gave 54, Got 21
I agree with metalguru since the XBox360 will only upscale SD DVD via VGA, not component or scart. Use an XBox360 VGA cable and set up the resolution to either 1360x768 or, if it wont accept that, 1280x720. My Dad has his laptop connected to a Tesco's Technosonic via VGA and it looks great. We had our Mirai 27" LCD connected to the XBox360 via VGA and the Xbox360 did a great job at upscaling (far better than the scaling of the Mirai). Here is a good price for the Official Microsoft VGA cable:
http://shop.gameplay.co.uk/webstore/...ga_hd_av_cable
Other than that I would buy the Sony NS76 DVD player. It is about £10-£15 over your budget but my Dad gets very good results on his LCD using both 720p and 1080i. I have tried it on our Mirai via HDMI and the results imho were better than the XBox360 upscaling on VGA. This is probably because the XBox360 uses 60hz over VGA rather than 50hz which PAL DVDs prefer. You also don't get the noise from the XBox360.
Hope this helps
'You ask me to help you? Man is evil! Capable of nothing but destruction': Dr Zaius: 'Beneath The Planet Of The Apes'
My DVD Collection
Dr Zaius is offline   Reply With Quote
dvd, ish, lcd, technosonic, upscaling, upto, £60
