Go Back   AVForums.com > Home Entertainment Players and Recorders > Blu-ray and DVD Players > DVD Players
Today's price checkPowered by
Panasonic DMR-EX769 160GB
LG DRT389H
Sony DVP-FX730
LG RHT497H 160GB
LG DRT389H
Sony DVP-FX730
LG RHT497H 160GB
Panasonic DMR-EX98V 250GB
Philips DVP3310
Panasonic DMR-EX79 250GB
Samsung DVD-H1080
Sony RDR-HXD995
Panasonic DMR-XS350 250GB
 More...Prices updated November 22nd at 10:30pm and include delivery.
Old 19-10-2002, 6:46 PM   #1 (permalink)
Thanks: Gave 1, Got 0
96 kHz/ 48 kHz??
On most dvd players there is an option of having an output of 96hHz or have it converted to 48kHz?? What is this for and what does it mean. What sources would output 96 and do most amplifiers take that frequency (like the denon 3802)?
Is there anything more I need to know about this frequency phenomenon, like the Philips Q50 has 4x overssamping and makes a 54mhz signal out af 13,5.. is this purely for video?
Can someone give me a 101 on this stuff?
keyser is offline   Reply With Quote
Old 21-10-2002, 10:53 AM   #2 (permalink)
Reiner's Avatar
Thanks: Gave 2, Got 12
There is one audio format on DVD Video called 24/96 (24bit/96kHz) - not to be confused with DVD-A though.
Basically it was supposed to be a high-end audio format on DVD Video disc, containing still images or very short video clips.
Initially it was prohibited to send the 24/96 signal down via the digital output for copyright reasons, as well there was a time when no AV amplifier/receiver could actually handle (decode) it. Thus you had to use the decoder in the player and connect it via the analog outs.
The reason for the downsampling was to protect the amplifier and / or speakers from the increased frequency range. Not that it might have been necessary, but better safe than sorry (I guess) ...
That's only related to the Video DAC (digital to analog converter).
Rgds,
Reiner
Reiner is offline   Reply With Quote
Old 21-10-2002, 6:24 PM   #3 (permalink)
Do current amplifiers like my denon 3802 accept 24/96kHz signals? Are there any dvd´s that have this format of sound?
Old 21-10-2002, 9:42 PM   #4 (permalink)
Thanks: Gave 1, Got 13
Keyser
The 3802 you have according to the Denon website has 24bit 96Khz Dacs
so theoretically should be able to process the digital signal. Best check the manual tho'.
Yes, you can still buy these audio DVD's - sometimes referred to as DAD's see - Chesky , as well as
Classic Records.
The quality is outstanding but the choice is somewhat limited.
A word of warning, don't be fooled into buying cd's which are 24bit/96Khz mastered. These are only cd's.
HTH.
Mike
MikeC is offline   Reply With Quote
Old 21-10-2002, 10:08 PM   #5 (permalink)
This is slightly aside from the topic, but seemed a good enough place to ask!
Im doing signal processing as one of my final year degree modules.....now from what im led to believe, if you sample a signal at a certain rate (the nyquist frequency) all information from the original signal can be maintained. Now before i go question my lecturer on whether he's spinning me porkies......what is the point in massively high sampling rates when using the same bandwidth of signal?
ad
buns is offline   Reply With Quote
Old 22-10-2002, 2:15 AM   #6 (permalink)
Reiner's Avatar
The point is to take more samples and thus allow a more accurate reconstruction of the original signal. If there aren't enough samples you need to interpolate the missing information, possibly resulting in a wrong (or rather less accurate) reconstruction.
The nyquist theorem says you must sample at least at double the frequency of the highest frequency in your signal, so for music (20Hz - 20kHz) this would be at least 40kHz (can't recall why CD actually samples at 44.1kHz - anyone?).
As for DVD-A (and SACD) they sample at much higher frequencies to increase the bandwidth, so if you have e.g. a DVD-A recording of 192kHz the highest frequency re-produced can be 96kHz.
One should also not forget that the low frequencies (say a bass at 65Hz) is still sampled at 192kHz when using PCM! Kind of waste actually ...
Rgds,
Reiner
Old 22-10-2002, 9:01 AM   #7 (permalink)
michaelab's Avatar
Thanks: Gave 0, Got 7
Yes - but why would anyone want to reproduce a sound at 96kHz! Not even dogs can hear that.
Since the CD sampling frequency of 44.1kHz captures all sounds audible by the human ear I really can't see how a higher sample frequency will make any difference.
AFAIK CD DACs don't do any 'interpolating' other than of course smooting the 'stair' shaped digital 'sound wave' into a smooth one. You could argue that with a higher sample rate there would be less 'smoothing out' to do, and you'd be right, but the eventual analog sound wave created wouldn't sound any different because any extra harmonics or fluctuations that a 192kHz sample rate would capture would necessarily be above 20kHz which we can't hear.
I haven't ever heard DVD-A or SACD. I'll believe it's better when I hear it.
Michael.
michaelab is offline   Reply With Quote
Old 22-10-2002, 9:09 AM   #8 (permalink)
NicolasB's Avatar
Thanks: Gave 46, Got 514
The ear is emphatically not a linear device. If you play a single pure note then the ear will more or less hear only that note; but if you play two or more notes at once then things get much moire complicated. As well as hearing the two notes themselves you begin to hear other notes mixed in - a note whose frequency is the sum of the frequencies of the two real notes, another one at the beat frequency (the difference in frequency between the two real notes) and others too.
What this means is that if you play a number of ultrasonic notes at once then you can end up with beat frequencies that do actually fall within the audible range. So while you don't hear sounds much above 20 kHz (and I might add in passing that some people can hear 22 or 23 kHz) the presence of ultrasonic sound components does actually modify one's perception of the frequencies that you can hear.
I would hypothesise there may also be some effect from how rapidly a note can go from zero to a high amplitude or vice versa - it can't do it in less time than the sampling interval.
NicolasB is offline   Reply With Quote
Old 22-10-2002, 9:37 AM   #9 (permalink)
michaelab's Avatar
Thanks Nicolas, that's the first believable explanation I've heard about why a higher sample frequency should make any difference. However, if these beat frequencies etc are artefacts created by the human ear (and don't really exist?) then surely we'd need to use speakers with a frequency response much higher than 20kHz to get any benefit from DVD-A or SACD?
Michael.
Old 22-10-2002, 9:55 AM   #10 (permalink)
NicolasB's Avatar
I don't know about any benefit, but I suspect you're basically right, yes. Some speakers do do this, of course. The KEF "Reference" series, for example, uses a "hypertweeter" which is rated at up to 50 kHz and has some response as high as 70. I think it's safe to assume that KEF wouldn't have bothered with that if it didn't make a perceptible difference to the sound quality.
Some headphones have quite a wide frequency response too. My faithful Sennheiser HD600 headphones are rated at 14Hz-39 kHz.
Old 22-10-2002, 11:32 AM   #11 (permalink)
Don't also forget that if you sample at 44.1Khz, you have to have incredibly steep low-pass filter set at just above 20Khz to remove ultrasonic junk.
These filters almost certainly affect frequencies below 20Khz ie can be audible.
Therefore, by sampling at the much higher frequency of 96/192 Khz, these filters can be
made less steep and at a higher frequency and will consequently not affect the
audible frequencies anywhere near as much.
Oversampling I beleive also has the same effect.
Mike
Old 22-10-2002, 12:33 PM   #12 (permalink)
so basically nyquist doesnt sample the signal without loss, rather it is an approximation?
ad
Old 22-10-2002, 12:37 PM   #13 (permalink)
NicolasB's Avatar
buns:
What Nyquist states is that in order to reproduce a component of the original signal that has frequency x you have to sample at a frequency of at least 2x.
So to reproduce a 20kHz signal you have to sample at >40kHz.
MikeC:
Good point.
Old 22-10-2002, 1:19 PM   #14 (permalink)
When stored digital audio research was being done in the 70s the digital audio data was encoded onto a video signal that could then be stored on a video tape, the sample rate was one that happened to be 40Khz + some headroom, and allowed easy encoding onto the video signal. Until CDR and the like came along CD images were still sent to manufacturers encoded on video tapes.
If you didn't need to store the audio data and were just transmiting it then you could choose a nice round number for the sampling frequency, which is why almost everything else has a sample rate different from CDs.
aardvark179 is offline   Reply With Quote
Old 22-10-2002, 1:24 PM   #15 (permalink)
michaelab's Avatar
Check out this web page:
http://www2.cs.ust.hk/faculty/layers...waveforms.html
..quite a good basic intro on sampling frequencies, Nyquist and aliasing (which happens if you try to sample a frequency higher than the Nyquist frequency, ie more than half the sample frequency).
Michael.
khz, khz or
