For listening to TV sound through the DAV you need to use an analog (stereo) connection, but that only works if the DAV has a free line input (e.g. AUX).
The TV needs an output to match, I assume it does not have one thus you require an adapter cable (Scart to RCA audio).
Piping the sound from the DAV to the TV isn't recommended as explained by Nobber22, as well the DAV would need to have pre-outs for this to work.
And again you may require the use of an adapter cable if the TV does not have a line input (white and red RCA connectors).
Rgds,
Reiner
