Go Back   AVForums.com > Home Entertainment Players and Recorders > Blu-ray and DVD Players > DVD Players
Today's price checkPowered by
LG DRT389H
Sony DVP-FX730
Panasonic DMR-EX769 160GB
LG RHT497H 160GB
LG DRT389H
Sony DVP-FX730
LG RHT497H 160GB
Philips DVP3310
Panasonic DMR-EX98V 250GB
Panasonic DMR-EX79 250GB
Panasonic DMR-XS350 250GB
Samsung DVD-H1080
Sony RDR-HXD995
 More...Prices updated November 23rd at 11:30pm and include delivery.
Old 28-01-2007, 11:51 AM   #1 (permalink)
Thanks: Gave 11, Got 15
1930 sa-cd connection
Hi all
i have a denon 1930 that i want to connect via sa-cd outputs to my sony stra-1200.
now the sony has 2 phono inputs for sa-cd but the denon has only the normal 6 outputs connections and 2 normal audio connections.
Do i connect the sony to the 2 audio or use the 6 separate ones?
Robert
RobTi is offline   Reply With Quote
Old 28-01-2007, 12:11 PM   #2 (permalink)
Mr Incredible's Avatar
Thanks: Gave 661, Got 1,190
Re: 1930 sa-cd connection
Does your Sony have EXT-IN for 5.1? i.e. phono inputs for Front L + R, Surrounds (L + R), Cenre and sub? If so, use those.
| Bob | | Sony KL-50W2 | Denon 3805 + POA-T10 | Denon 2900 | B&Ws 604/602/LCR600 s3 7.1 | SVS B12-ISD | BFD | Showcenter 200 | Sky+(250GB) | Scorpion & Mark Grant |
| GA-EP45-UD3R | Q6700 @ 3.52GHZ | 8GB OCZ @ 1056 | XFX GTX260 | Corsair 650W TX | Thermalright 120 Extreme | Akasa Infinity |
Mr Incredible is offline   Reply With Quote
Old 28-01-2007, 12:14 PM   #3 (permalink)
Hi yes it has those and i was going to use them but when examining the back panel it has 2 phono inputs marked as sa-cd, so that threw me
Old 28-01-2007, 12:26 PM   #4 (permalink)
OK! I may be a bit sketchy here in my knowledge, but I think Sony were the original developers/owners of SACD which was an attempt to prevent "CD" copying. There are no commercial products out there that will copy or duplicate an SACD "CD". To prevent people from intercepting the digital stream and ripping the audio out, Sony provided some form of encryption which either the SACD player had on board, or if it passed it to an external decoder over a secure connection. For Sony products it may be that they could guarantee this delivery mechanism through the two phonos route.
On the later Denon amps (and after a long protracted battle to get SACD licensed over the D-Link) are able to connect to the SACD player and get digitally connected for decoding by the amp. However, for those people without this connection the 5.1 analogue output was created. The SACD is decoded into multi-channel analogue output for connecting to amps without a proprietary license/encryption for SACD.
I think!
Old 28-01-2007, 4:10 PM   #5 (permalink)
Thanks: Gave 4, Got 22
Mr Malice - your knowledge is "sketchy" to say the least.
Wikipedia can be your friend.
To the OP - a lot of SACDs are multichannel. To take advantage of this, you should connect the 5.1 analogue outputs of the player to the 5.1 analogue inputs on your amplifier.
The amplifier has a stereo, analogue input marked SACD for two basic reasons. The first is because there are many stereo-only SACD players and the second is because your amp is made by Sony, the co-developers (with Philips) of the format.
There are some great recordings on SACD. Enjoy.
charliecossie is offline   Reply With Quote
Old 28-01-2007, 6:38 PM   #6 (permalink)
Thanks all
connected by 6 cheapo leads at the moment till i get something better
Robert
1930, connection, sacd
