Go Back   AVForums.com > Home Entertainment Players and Recorders > Blu-ray and DVD Players > DVD Players
Today's price checkPowered by
Sony DVP-FX730
LG DRT389H
Panasonic DMR-EX769 160GB
LG RHT497H 160GB
Sony DVP-FX730
LG DRT389H
LG RHT497H 160GB
Philips DVP3310
Panasonic DMR-EX98V 250GB
Panasonic DMR-EX79 250GB
Samsung DVD-H1080
Panasonic DMR-XS350 250GB
Sony RDR-HXD995
 More...Prices updated November 22nd at 9:30am and include delivery.
Old 04-01-2007, 5:57 PM   #1 (permalink)
Thanks: Gave 8, Got 4
Compared Oppo 981 to pioneer 868i
I bought an Oppo dvd player just to see what all the fuss was about, it arrived and it is a very good package for the price. After calibrating the tv with the video essentials disk, out of the box the player's contrast and colour are very high compared to the pioneer. Colours and contrast are very very good. However the edges are very jagged in certain scenes compared to the pioneer and I don't see any changes whatsoever when you try upscaling or turn the faroudja processing on/off. This aside though on a smaller screen (was tested on a 50" pioneer plasma) the edges will not be so blitheringly obvious and it would be an excellent player.
kazino21 is offline   Reply With Quote
Old 04-01-2007, 6:00 PM   #2 (permalink)
Thanks: Gave 200, Got 179
Re: Compared Oppo 981 to pioneer 868i
Would you like to sell me the 981 then please
First refusal
Pio 507XD, Oppo 981HD, Onkyo TX-SR605, Sky HD, Kef 1005.
KinkyAffro is offline   Reply With Quote
Old 04-01-2007, 6:06 PM   #3 (permalink)
Thanks: Gave 58, Got 104
Hi there. Something doesn't sound quite right there - I have used an Oppo 971 outputting to a Sony HS60 and onto a 90" screen and I got no noticeable jaggies, and for me there was an obvious difference when DCDi was turned off. Is your plasma screen's native resolution 720p?
Mark Haywood is online now   Reply With Quote
Old 04-01-2007, 8:00 PM   #4 (permalink)
Thanks: Gave 41, Got 24
Mine was very jaggy and rubbish out of the box and the auto pal/NTSC setting kept forcing me to NTSC. Once I forced it to ouput pal, then moved up to 1080p (or 1080i) all my troubles were gone
Chronology - Sony KDL-40x2000, scandyna 5.1 micropods, Sony 1200ES, SkyHD, Oppo981H, Linn classic II, Linn Katans, good ole NAD3020b, Dual deck, Linn Index Plus, records and tapes
Smurkenstein is offline   Reply With Quote
Old 05-01-2007, 9:17 AM   #5 (permalink)
next week my 891 will arrive and I had question. I'm planning on upscaling to 1080p even though my HD70 can only perform 1080i and 720p resolution. Will my HD70 still be able to receive the 1080p signal even when it is converted to 720p later?
| Themescene HD70 | PS3 | Pioneer VSX-1015 | SVS: 4x SBS-01 | SCS-01 | PC13 ULTRA | BFD |
kick ass sub is offline   Reply With Quote
Old 05-01-2007, 1:01 PM   #6 (permalink)
My screen is a Samsung 40" LCD, but I had done the comparison on my friends Pioneer as I took the Oppo over to his and obviously being on a higher quality screen any problems or strenghts would be easier to see. The native on my screen is 720p, I have it forced onto PAL aswell, I understand from the manual what DCD is meant to do and I have looked for these things but can't see them. Maybe there is a scene in star wars (I have all the discs) that you can tell me what to look out for in the changes DCDi can make. Also what is the difference you can see when you upscale with the OPPO?
Old 05-01-2007, 3:30 PM   #7 (permalink)
james_uk9's Avatar
Thanks: Gave 16, Got 32
Originally Posted by kick ass sub View Post
Highly unlikely, the fact that your tv doesnt do 1080p means exactly that. It cannot receive a 1080p signal and then downscale to 720.
Hitachi 42PD7A10 - Hitachi PJ-TX300 - Sapphire 92" 16:9 Screen - HTPC - V+ - Xbox 360 - Yamaha AX759SE Amp - Harmony 885 - Kef Q7 - MS905i - Kef Q1 - Tannoy TS12 - Evoke 3 - Pocketdab 1500 - Nokia N95 8GB.
james_uk9 is offline   Reply With Quote
Old 06-01-2007, 9:57 AM   #8 (permalink)
so the image will be just black when I try to run a 1080p signal to my HD70?
Old 06-01-2007, 12:08 PM   #9 (permalink)
Thanks: Gave 819, Got 1,086
Player needs to be set to video 2
Do everything with excess, even excess
Nic Rhodes is offline   Reply With Quote
Old 06-01-2007, 12:28 PM   #10 (permalink)
Thanks: Gave 147, Got 162
Yes. That's what I got on a Sagem 720p DLP TV. (A black screen).
mray is offline   Reply With Quote
Old 07-01-2007, 7:49 AM   #11 (permalink)
What exaclty does video 2 and video 1 turn off in the unit? doesn't give too much info in the manual...
Old 07-01-2007, 9:35 AM   #12 (permalink)
There's some info here - although it relates to the Oppo OPDV971H I think things are pretty much the same.
868i, 981, compared, oppo, pioneer
