Go Back   AVForums.com > Home Entertainment Players and Recorders > Blu-ray and DVD Players > DVD Players
Today's price checkPowered by
Sony DVP-FX730
LG DRT389H
Panasonic DMR-EX769 160GB
LG RHT497H 160GB
Sony DVP-FX730
LG DRT389H
LG RHT497H 160GB
Philips DVP3310
Panasonic DMR-EX98V 250GB
Panasonic DMR-EX79 250GB
Samsung DVD-H1080
Panasonic DMR-XS350 250GB
Sony RDR-HXD995
 More...Prices updated November 22nd at 3:30am and include delivery.
Old 19-08-2002, 3:11 PM   #1 (permalink)
Mattdyson7981
Posts: n/a
Question Cheaper DVD Players
Hi can anyone help me i am looking to buy a cheaper Dvd player i was looking at the Mustek V562 does anyone know of any reviews is it any good. I was looking at the Yelo 800 DVD and the Kiiro 838D but they are both out of stock. Does anyone know where they are in stock for around £100.
Many thanks
Old 20-08-2002, 1:54 PM   #2 (permalink)
Delorian
Posts: n/a
You would be much better of paying the few quid more for a well known name like the Tosh 220. If you don't mind getting it region 2 (you should mind, but IF you don't) you'll be able to pick it up quite cheap.
However, if you are fixed on staying below £100 I hear the Yelo is well up to the task. I seem to remember the Yelo and Kiiro being made by the same ppl, with the Yelo being older but better. I presume you saw these players at amazon.co.uk, but if not, check it out, they all have user reviews. I have never heard of the Mustek.
Bear in mind, alot of the unknown brands take DVD ROM type drives and build players around them, not that that's a bad thing. Also, try and find out how good their service is. There could be a difference there.
Finally, type each brand name into the search engine down the bottom of these forums and find out what ppl here have already said about them. Them try totalDVD.net, and lastly try google.
Good luck...
cheaper, dvd, players
