Go Back   AVForums.com > Home Entertainment Players and Recorders > Blu-ray and DVD Players > DVD Players
Today's price checkPowered by
Panasonic DMR-EX769 160GB
LG DRT389H
Sony DVP-FX730
LG RHT497H 160GB
LG DRT389H
Sony DVP-FX730
LG RHT497H 160GB
Panasonic DMR-EX98V 250GB
Philips DVP3310
Panasonic DMR-EX79 250GB
Samsung DVD-H1080
Sony RDR-HXD995
Panasonic DMR-XS350 250GB
 More...Prices updated November 22nd at 9:30pm and include delivery.
Old 19-08-2002, 12:20 PM   #1 (permalink)
tman's Avatar
Thanks: Gave 8, Got 40
Tosh DVD firmware
I have a multi-region Tosh SD-510e. I was under the impression that this model can be firmware upgraded from a bootable CD/DVD. What I don't know is;
What is the current firmware version for this player, and how can you find out which version you have?
Would a genuine firmware upgrade screw up a multi-region modified player?
Is there a site where these upgrades are available, or is it directly from Toshiba.
Am I heading up completely the wrong tree, and talking rubbish?
The reason I ask about this is that I have had the whole player lock on me twice now. Generally, it's fine, but it's a bit concerning.
tman is offline   Reply With Quote
Old 19-08-2002, 9:50 PM   #2 (permalink)
kevb's Avatar
Thanks: Gave 3, Got 3
Do you have your player in a confined space. I had a similar thing happen to me on two occasions. I moved my player to a different shelf so it had no equipment directly below or above and it has been fine ever since, even in the hot conditions recently. I think its very sensitive to heat from underneath it.
0 to naughty in 6 seconds
kevb is offline   Reply With Quote
Old 19-08-2002, 10:12 PM   #3 (permalink)
snyphr's Avatar
Re: Tosh DVD firmware
With no disc in machine on remote press zoom, 6, 0, 6, zoom
[/B]
Yes it would revert back to region 2 only
[/B]
Toshiba only and only to the priveledged few...
[/B]
No...
The reason I ask about this is that I have had the whole player lock on me twice now. Generally, it's fine, but it's a bit concerning. [/B]
1)If a player gets too hot it will lock up.
2)If you play a disc that has fingerprints or resedue of any sort it will lock up or mpeg (big green pixels).
3)Dirty lens can cause problems
4)Home made/non original material can freeze
BTW do you know if your Toshiba was ever recalled and fixed? Toshiba recalled all the SD510e after launch to fix a problem with the RGB video out. May have been other bugs but that was the official line....Speak to Toshiba.....
Work smarter NOT harder. Fail quicker with style & grace. Learn from your failures to return stronger.
snyphr is offline   Reply With Quote
Old 20-08-2002, 11:17 AM   #4 (permalink)
tman's Avatar
Thanks for the info.
I have a dedicated TV bench (from IKEA), that has four spaces for kit. Currently, I have the DVD on the top shelf above the amp. I may well have to check on heat levels if the Tosh is prone to this problem, as the amp gets pretty hot.
Guess I'll have to stick with the current firmware version then. I've only had the player a few weeks, so I can only assume it's a version with the RGB out problem fixed (I use component connections to a plasma anyway). I doubt if Toshiba would touch my player with a cattle prod anyway as it's been modified!
I'll check my firmware version and re-post.
dvd, firmware, tosh
