DVD-A and SACD are only allowed to be output from the player as multichannel analogue signals. (unless you count some ultra expensive exceptions from Meridian, a digital link from Denon which will not pass copyright DVD-A material and only works with their amp, and the up&coming Pioneer firewire link, again only particular amps/players).
Even if you could pass a digital signal, there aren't sperate multichannel decoders for DVD-A and SACD (again with notable exceptions).
We are therefore meant to connect our 5.1 audio from the player to amp by analogue cable. I just bought quite a neat Ixos one (sorry can't recall the code for it) tha does the job very neatly. Otherwise use 3 of your favourite quality interconnects.
Having a digital connection is handy to use your usual Dolby and DTS decoder for movies,esp. for amps with 6.1 (DTS-ES etc) reproduction systems (which are not decoded by any DVD-A or SACD players I know of).
If possible you want this to be a 'direct' input that passes the higher bandwidth signal without messing it around. On Denon amps this is supplied as 'Ext In' and likely your amp will have a similar function.
Hope this helps.
Regards,
Ian Guinan
p.s. Did you know the 747 was due to be replaced very shortly (757?).. may be some bargains to be had if you've set your heart on this player.
