Go Back   AVForums.com > Home Entertainment Players and Recorders > Blu-ray and DVD Players > DVD Players
Today's price checkPowered by
LG DRT389H
Sony DVP-FX730
Panasonic DMR-EX769 160GB
LG RHT497H 160GB
LG DRT389H
Sony DVP-FX730
LG RHT497H 160GB
Panasonic DMR-EX79 250GB
Philips DVP3310
Panasonic DMR-EX98V 250GB
Panasonic DMR-XS350 250GB
Samsung DVD-H1080
Panasonic DMR-EZ48
 More...Prices updated November 24th at 9:30pm and include delivery.
Panel upscaling overrrides dvd player upscaling? LoadofTosh High Definition TV Hardware 2 20-09-2006 11:03 AM
Themescene HD72i and Sony DVP-NS76H DVD Player - upscaling issues BrownySV Projectors 16 04-09-2006 9:45 AM
Sony KDFE50A12U - upscaling DVD player bandicoot Rear Projection Televisions 1 16-08-2006 6:24 PM
Best Upscaling DVD Player to partner Sony Bravia KDL32-V2000U? Aljrob DVD Players 7 16-07-2006 7:34 AM
Old 23-10-2006, 7:47 PM   #1 (permalink)
Best upscaling DVD player for Sony KDL32V2000?
Can someone please help me on this one. I am looking to get an upscaling dvd player for my Sony KDL32V2000 LCD TV. I was looking at the Sony DVPNS92V but have heard there are picture shift problems when using the HDMI connection (which i want to use). Also, the screen wont adjust to wide/smart when on 1080i. Would a change in firmware correct this? I was also looking at the Denon 1920 but apparently there are lip sync problems. Can anyone suggest a top notch dvd player which will give me the best quality without all of these defects?
MARTIN25 is offline   Reply With Quote
Old 26-10-2006, 9:58 AM   #2 (permalink)
Re: Best upscaling DVD player for Sony KDL32V2000?
Actually, mes in the same boat, same tv as yourself, and same problem with dvd players. Someone out there, any advice
Ta
Imran_1 is offline   Reply With Quote
Old 27-10-2006, 12:55 PM   #3 (permalink)
Thanks: Gave 5, Got 15
Sony DVP-NS76H
Tom
If the world didn't suck we'd all fall off.
tomandjo2 is online now   Reply With Quote
Old 27-10-2006, 1:47 PM   #4 (permalink)
The problem with the DVP-NS76 is that it doesnt have as many features as the one i currently have (DVP-NS955) ie 5.1 channel outputs which I need. Any other suggestions? Hasnt the glitch on the NS92V been sorted out?
Old 27-10-2006, 1:55 PM   #5 (permalink)
Thanks: Gave 100, Got 126
I went to a shop today to buy Sony DVP-NS76H and they told me that an updated version is coming next week called DVP-NS76E and that the price will be 20 euro less!
Does anyone know the difference between the two?
Yannis is offline   Reply With Quote
Old 27-10-2006, 8:29 PM   #6 (permalink)
Conspicuous Member
Crustyloafer's Avatar
Thanks: Gave 154, Got 1,021
These all fit into the "top notch" category:
Arcam FMJ DV139: £1800 (out very soon)
Arcam DV137: £1250
Denon DVD-3930: £1000
Denon DVD-2930: £600
Oppo BDP-83, Sony PS3 (250GB), Humax Foxsat HDR (1TB), Sonos ZP90 & Cambridge Audio DACMagic, Spectral DMC-10, Yamaha DSP-Z7 & Bryston 4BSST, PMC PB1i, PMC CB6i, PMC Wafer 2 & REL Stentor 3 with Anti-Mode 8033, Panasonic TX32-PL1 & Panasonic PT-AE3000 onto Beamax R-Series Manual Screen (213x122)
Crustyloafer is offline   Reply With Quote
Old 27-10-2006, 8:40 PM   #7 (permalink)
NX3
Thanks: Gave 17, Got 62
In the good but not overly expensive bracket the Pioneer 696 for about £120 is an excellent player. It upscales over HDMI
NX3 is offline   Reply With Quote
Old 27-10-2006, 8:54 PM   #8 (permalink)
Thanks: Gave 20, Got 6
i've got the Sony DVPNS92V. its a beauty!! any you find now should have the picture shifting issue fixed & the latest firmware on. if you can get it in black, it looks the business too!
plenty of info here Sony NS92V HDMI Player and pictures to show off its good looks!
got mine from here http://www.mrmdvd.com/catalog/. they'll also tell you if it is the latest version
good luck!
Stuart P is offline   Reply With Quote
Old 28-10-2006, 4:06 PM   #9 (permalink)
The sony is cheaper here
trulskaare is offline   Reply With Quote
dvd, kdl, player, sony, upscaling
