Go Back   AVForums.com > Home Entertainment Players and Recorders > Blu-ray and DVD Players > DVD Players
Today's price checkPowered by
LG DRT389H
Sony DVP-FX730
Panasonic DMR-EX769 160GB
LG RHT497H 160GB
LG DRT389H
Sony DVP-FX730
LG RHT497H 160GB
Philips DVP3310
Panasonic DMR-EX98V 250GB
Panasonic DMR-EX79 250GB
Panasonic DMR-XS350 250GB
Samsung DVD-H1080
Panasonic DMR-EZ48
 More...Prices updated November 23rd at 8:30pm and include delivery.
Component to Scart - no pin 8 signalling :( AnfieldRoar Interconnects, Speaker Cables and Switches 0 20-10-2006 4:33 AM
scart pin question andrewq Interconnects, Speaker Cables and Switches 0 29-12-2004 11:02 AM
Scart to 15 pin baldbird Plasma Televisions 1 24-05-2004 4:26 PM
Old 20-10-2006, 4:34 AM   #1 (permalink)
I have a DVD player connected to my Toshiba widescreen TV via a component to scart adapter. The dvd player setup is set to 16:9 screen with Pal video.
There are two issues:
1. When I switch the dvd on it doesn't signal my TV to switch to the correct input. My TV does this when I switch my other scart connected equipment on, e.g. DVD player and Sky+
2. The dvd player doesn't signal my TV to go widescreen. The TV is set to auto-size so when I watch Sky+ it auto-switches to 16:9 widescreen, and when I watch terrestrial channel 5 it auto-switches to auto-size to show the 4:3 screen as fullscreen. It all works perfectly except for the dvd player signal which stays at 4:3 for some reason.
Any ideas on how to make the dvd player (or a scart adapter) to fix the above issues?
Many thanks,
Andy
AnfieldRoar is offline   Reply With Quote
Old 20-10-2006, 5:33 AM   #2 (permalink)
Conspicuous Member
Thanks: Gave 4, Got 1,199
Re: Component to Scart - no pin 8 signalling :(
It's because the signal required can not be sent down the component cable. Pin 8 has a low voltage DC supply added to it from the source equipment and this only comes via the source equipments own scart outlet.
Andy98765 is offline   Reply With Quote
Old 20-10-2006, 7:52 AM   #3 (permalink)
Thanks: Gave 3, Got 3
Yes, there are lots of pins in a Scart cable which carry all sorts of information, along with component video in RGB form. You've only got 3 cables in a component cable, so you don't get all the information on the other pins (like your pin 8 switching).
Slimchandi is offline   Reply With Quote
Old 20-10-2006, 11:34 AM   #4 (permalink)
Many thanks for the replies but as I said I knew this and my question was did anyone have ideas on how to make the dvd player (or a scart adapter) to fix the above issues?
I really cant find any info on the net anywhere on how to auto-switch a component->scart input. Surely there must be some sort of connector or AV box that will set pin 8 high when a video signal starts and then set pin 8 low when the signal disappears?
Old 22-10-2006, 7:31 AM   #5 (permalink)
Thanks: Gave 0, Got 5
Do you notice a big jump in PQ between component and rgb then......??
If not, just use the scart output on the dvd player....problem solved.
If i remember correctly, toshiba's convert all input signals to s-vid quality anyway ( or they use to ).
Pioneer 435XDE, Pioneer 575, PS3, Sky+, MA BR2's, MA B Center, M&K K4's, Eltax HB2's, SVS PB12-Ultra, Sony 2400ES, Cheap Turntable, Loads of remotes.
chris is online now   Reply With Quote
Old 22-10-2006, 12:23 PM   #6 (permalink)
Greg Mandel's Avatar
Thanks: Gave 7, Got 20
If you did find a box that would do that, think about where it would set the pin... that's right, on the scart socket, where your component leads are not connected. So even if such a thing did exist, how would setting the scart pin high (which would simulate a signal on the scart socket) help your TV detect and enable the component input?
Unless your TV can detect a component input and can switch to the right input, you're not going to be able to fake it with a signal on the scart socket. At best, you'll get your TV switching to the scart socket instead of component input. That's why there's no such thing as the magic AV box you are hoping for. As the component standard doesn't have anything for detecting a signal, most TVs just don't seem to support it.
You would probably be better off getting one of the various aftermarket programmable remotes where you can program a key to send all the right button presses for you in the form of a macro. It will have the same effect as turning on your player and automatically switching to the component input.
Greg Mandel is offline   Reply With Quote
component, pin, scart, signalling
