| Re: Whats difference between PCM and RAW?
PCM=Pulse Code Modulation (outputs in 2 channel stereo)
I'm sure someone will be able to give you a far more technical answer but the quick answer is, unless you set your DVD's audio output to RAW(Bitstream) you will not be able to output 5.1 via digital co-ax/optical cable to an AV Amp/Receiver for surround sound (5.1/DTS).
__________________ AV Setup Panasonic TH42PZ81 | Hitachi PJTX200 | Toshiba HD-EP35 | Squeezebox 3 plus itouch/ipeng controller | Xbox360&PS3 | Sky+HD | Denon AVR3805 | Focal Chorus 816V/806V/CC800V | SVS PB1-ISD | Harmony One | |
