Go Back   AVForums.com > Home Entertainment Players and Recorders > Blu-ray and DVD Players > DVD Players
Today's price checkPowered by
Sony DVP-FX730
LG DRT389H
Panasonic DMR-EX769 160GB
LG RHT497H 160GB
Sony DVP-FX730
LG DRT389H
LG RHT497H 160GB
Philips DVP3310
Panasonic DMR-EX98V 250GB
Panasonic DMR-EX79 250GB
Samsung DVD-H1080
Panasonic DMR-XS350 250GB
Sony RDR-HXD995
 More...Prices updated November 22nd at 1:30pm and include delivery.
Old 25-07-2006, 9:46 PM   #1 (permalink)
Thanks: Gave 4, Got 4
Recommended digi-coax cable for Toshiba SD-360?
Hello all,
DVD player broke and made a bit of a rash decision to buy the Toshiba SD-360 DVD player at the weekend in a rush; only to get it home and realise that it doesn't have an optical audio out, just a digital coax audio out.
So, is there basically any difference between these two types of connection? And if not, any recommendation on which cable or what to look out for?
Many thanks in advance
CaptainC is offline   Reply With Quote
Old 25-07-2006, 9:54 PM   #2 (permalink)
WGLOVER's Avatar
Thanks: Gave 52, Got 74
Originally Posted by CaptainC
Hello all,
Assuming you have an amplifier with a coax input, you should have no problems.
An coax lead lead can be purchased quite cheaply. In fact an ordinary phono lead works.
Optical is not prone to electrical interference, but the sound quality difference is negligible, some saying coax is superior.
WGLOVER is offline   Reply With Quote
Old 25-07-2006, 10:05 PM   #3 (permalink)
Thanks: Gave 10, Got 13
This is a whole other debate.
It should'nt sound any different at all as it's a digital connection and is just 1's and 0's but some people swear blind that a better cable makes a difference.
Any bog standard coax should be fine.
Sanyo Z3 projector, Playstation 3,Panasonic th37pa20 plasma, yamaha rxv440 receiver, Ruark Talisman Floorstanding fronts, Kef reference 100 centre,Mission M7DS Rears, Rel Quake Sub, One for all Kameleon Remote.
gingerone is offline   Reply With Quote
Old 25-07-2006, 11:46 PM   #4 (permalink)
Thanks: Gave 115, Got 95
QED do one for approx £20. does the job. More importantly should be easy to get hold of. Maplins and B&Q stocked the Thor range of cables and they are good value.
pwood is offline   Reply With Quote
Old 26-07-2006, 1:32 AM   #5 (permalink)
Conspicuous Member
davepuma's Avatar
Thanks: Gave 164, Got 1,383
I would stick with a Profigold co-ax cable like thishttp://www.audiovisualonline.co.uk/d...e/display.html
I prefer co-ax, purely because I've never had a co-ax connection fail on my amp, yet I have with optical. I think that's an overheating issue.
AV Setup Panasonic TH42PZ81 | Hitachi PJTX200 | Toshiba HD-EP35 | Squeezebox 3 plus itouch/ipeng controller | Xbox360&PS3 | Sky+HD | Denon AVR3805 | Focal Chorus 816V/806V/CC800V | SVS PB1-ISD | Harmony One |
davepuma is offline   Reply With Quote
CaptainC (26-07-2006)
Old 26-07-2006, 6:37 AM   #6 (permalink)
Thanks for the advice guys.
I'll get myself one asap - seems weird watching a DVD without surround now :¬)
cable, digicoax, recommended, sd360, toshiba
