Go Back   AVForums.com > Home Entertainment Players and Recorders > Blu-ray and DVD Players > DVD Players
Today's price checkPowered by
Sony DVP-FX730
LG DRT389H
Panasonic DMR-EX769 160GB
LG RHT497H 160GB
Sony DVP-FX730
LG DRT389H
LG RHT497H 160GB
Philips DVP3310
Panasonic DMR-EX98V 250GB
Panasonic DMR-EX79 250GB
Samsung DVD-H1080
Panasonic DMR-XS350 250GB
Sony RDR-HXD995
 More...Prices updated November 21st at 7:30pm and include delivery.
Old 25-07-2006, 5:34 PM   #1 (permalink)
Thanks: Gave 117, Got 257
Subtitles appearing off screen? Help!!
Hi there.
Not sure if i'm in the right forum but I guess it may be a problem that several of you have come across?
I have a JVC THA-75R all in one system connected via scart RGB to a Panasonic TX36PL32 CRT. When playing back certain DVD's (such as House of Flying Daggers), if I set the screen to the correct ratio (widescreen in this case) there are black bars at the top and bottom as expected (aspect ratio 2.35:1). The subtitles are displayed in the black bars at the bottom but if there is more than one line they 'fall off' the bottom of the screen. The only way to make all the subtitles visible is to set the aspect ratio to make the picture smaller such that the black bars are larger and there are then black bars down the side!!!! I can't seem to work out if there is a way to fix this, which isn't helped by the fact that I'm unable to locate my tv's instruction manual!!!
Is there a way to sort this either via the tv or the DVD player or is this simply the way the DVD has been authored and I'm stuck with it?
Any help is much appreciated!!
stuartbrown21 is offline   Reply With Quote
Old 27-07-2006, 7:22 PM   #2 (permalink)
Nobody got any bright ideas? Anyone else got House of Flying Daggers on DVD, can you get all the subtitles on screen at once without making the picture tiny?
Old 27-07-2006, 9:31 PM   #3 (permalink)
Thanks: Gave 3, Got 2
does your tv have a 16:9 setting? Widescreen setting is usually not quite the same shape, therefore you should see all subtitles when set to 16:9
loudnproud is offline   Reply With Quote
appearing, screen, subtitles
