Free electronics advice and information
3.5 million visitors each month
Go Back   AVForums.com > Home Entertainment Players and Recorders > Blu-ray and DVD Players > DVD Players
Latest popular product pricesPowered by
Panasonic DMR-EX769 160GB
Coby TFDVD7008
Sony DVP-FX730
Samsung DVD-H1080
Coby TFDVD7008
Sony DVP-FX730
Samsung DVD-H1080
Panasonic DMR-EX98V 250GB
LG DRT389H
Panasonic DMR-EZ48
Panasonic DMR-EX 89 400GB
Panasonic DMR-XS350 250GB
Panasonic DVD-LS84
 More...Prices updated March 22nd at 10:30am and include delivery.
Old 28-05-2006, 1:05 PM   #1 (permalink)
chinets
Posts: n/a
Question What is DSD and isn't it the same as SACD??? HDCD does not light up on Rotel 1098?
Hi Everyone,
I found CDs that say Telerac DSD format or simply a DSD CD. What is DSD besides Direct streaming?? I though that DSD meant that it is a SACD CD format?? Am I wrong?? So what is the difference between DSD and SACD??
Also My Rotel Processor 1098 does not Indicate with a light or any indication that I am palying HDCD on my Rotel TCD-1072. Why?? The RCD 1072 has a red light that turns on when you play an HDCD CD but the processor 1098 does not indicate anyhting ( Light or anything). Am I receiving a true HDCD signal from my 1098 processor in HDCD or not?? I can't tell!!!!!!!!!!!! If there is no indication on my processor, except from my CD player 1072 that I am playing HDCD, then how would I know if my processor is really actually playing my 1072 in HDCD??Hope that explains things.
Thanks in advance for all your help,
Chinets
Old 28-05-2006, 2:34 PM   #2 (permalink)
Thanks: Gave 23, Got 10
Well, I'm not sure, but, assuming you mean Telarc DSD, I think this means they mastered the recording in DSD (Direct Stream Digital) which is the bit-stream format directly encoded on SACDs. However, in this case, apparently, all Telarc's original DSD recordings are directly down-converted to produce the CD master, using a special process called "SBM Direct". So, DSD is the format used directly on SACD, but the DSD master can be down-converted to PCM format for regular CDs.
zeropoint is offline   Reply With Quote
Old 28-05-2006, 3:09 PM   #3 (permalink)
chinets
Posts: n/a
Thanks Zeropoint!!!!!!!
Thanks Zeropoint for your kind help!!!!!!!!!
Old 29-05-2006, 12:06 PM   #4 (permalink)
Thanks: Gave 3, Got 3
Considering the DSD stream will have been doubtless created from a PCM one in the first place, it seems to be an utter waste of time going from PCM>DSD>PCM.
Why bother?
Especially considering the monstrous noise shaping required to make DSD listenable.
All there is above 23KHz in SACD is noise, and lots & lots of it.
neilwilkes is offline   Reply With Quote
1098, dsd, hdcd, light, rotel, sacd
Copyright © 2000-2010 M2N E. & O. E.
