Go Back   AVForums.com > Home Entertainment Players and Recorders > Blu-ray and DVD Players > DVD Players
Today's price checkPowered by
Sony DVP-FX730
LG DRT389H
Panasonic DMR-EX769 160GB
LG RHT497H 160GB
Sony DVP-FX730
LG DRT389H
LG RHT497H 160GB
Philips DVP3310
Panasonic DMR-EX98V 250GB
Panasonic DMR-EX79 250GB
Samsung DVD-H1080
Panasonic DMR-XS350 250GB
Sony RDR-HXD995
 More...Prices updated November 22nd at 5:30am and include delivery.
Old 26-05-2006, 9:21 AM   #1 (permalink)
Thanks: Gave 0, Got 3
Toshiba 360 or Samsung HD-950 ?
looking to buy a DVD player this weekend that has HDMI, Divx etc.
Have narrowed down my choice to
Toshiba 360
Samsung HD-950
Samsung HD-860
Which one would you recommend.... i heard that the previous Toshiba Model 350e had some freezing issues, do you know if they have been sorted on the 360 ? Also, are there easy handset hacks for all these models to make them region free ? Which of them has been the most reliable ?
Thanks in advance
oldskoolforever is offline   Reply With Quote
Old 26-05-2006, 9:34 AM   #2 (permalink)
Thanks: Gave 919, Got 472
I`ve got the 950 (although i screwed up my first one messing with the firmware) and i really like it. PQ is pretty damn good through the HDMI.
Setup menus are good and easy too
(((Flickr)))
Paulie-W is offline   Reply With Quote
Old 26-05-2006, 9:41 AM   #3 (permalink)
Syk
Syk's Avatar
Thanks: Gave 35, Got 26
I am after a new machine too and have been looking at the Toshiba 360, but it only has digital coaxial and I need optical. Have you seen the picture quality via component yet?
My other machine of interest is the Pioneer 696, although £160.00 is right at the top end of my budget range..................The machine is not on Pioneer's website as yet, but AVLand of Wellingborough have pictures and spec on their website.
Syk is offline   Reply With Quote
Old 26-05-2006, 9:43 AM   #4 (permalink)
is it easy to make region free from the handset ? Also... what was your firmware issue & why were you trying to upgrade it ?
Old 26-05-2006, 10:07 AM   #5 (permalink)
PQ by component is pretty good.
Reigon free is a very easy handset hack. I messed with the firmware to try to get hdcp out. Some people manage it, i didn`t. happens
(((Flickr)))
Old 26-05-2006, 12:42 PM   #6 (permalink)
sounds good to me, i assume both players support DTS as well ? What are the actual differences between the Samsung 950 & Samsung 860 ?
Old 26-05-2006, 1:01 PM   #7 (permalink)
I`m not too sure, but i have read that there seem to be a few problems comming up with the 860.
I just googled for reviews etc.
(((Flickr)))
Old 26-05-2006, 1:27 PM   #8 (permalink)
Syk
Syk's Avatar
Great!!
you'd think with all the latest technology out there, you would'nt have problems already with a new machine like the 860. It's getting so I dare not spend my money and settle on the Philips DVP 3005 (I think) I saw in Virgin Records - at least that had prog scan for £40.00.
Not too much if there ends up being issues................
Old 26-05-2006, 1:30 PM   #9 (permalink)
Thanks: Gave 33, Got 24
Personally I`m waiting for more information on the new Pioneer players: 490, and the 6 series.
Spoony
Spoonman2 is offline   Reply With Quote
Old 26-05-2006, 1:33 PM   #10 (permalink)
Syk
Syk's Avatar
Hi Spoonman
The Pioneer 696 would be my choice.
360, hd950, samsung, toshiba
