Go Back   AVForums.com > Home Entertainment Players and Recorders > Blu-ray and DVD Players > DVD Players
Today's price checkPowered by
Sony DVP-FX730
LG DRT389H
Panasonic DMR-EX769 160GB
LG RHT497H 160GB
Sony DVP-FX730
LG DRT389H
LG RHT497H 160GB
Philips DVP3310
Panasonic DMR-EX98V 250GB
Panasonic DMR-EX79 250GB
Samsung DVD-H1080
Panasonic DMR-XS350 250GB
Sony RDR-HXD995
 More...Prices updated November 22nd at 12:30pm and include delivery.
Old 29-04-2006, 10:53 PM   #1 (permalink)
Baron Von Doom's Avatar
Thanks: Gave 150, Got 56
dvd for panasonic plasma
im looking for a new dvd player to be connected to a panasonic pwd8 plasma.
ive not set a price yet.
im wondering if any one can recommend a price point i should be looking at that would be paired right with the plasma.
i dont want one to cheap so i dont get the best picture from the screen.
also i dont want to spend to much if the screen cant show what the dvd is capable of.
does anyone know what sort of price dvd player would match the screen?
any recommendations of players?
will probably be using component but can also use an hdmi conection.
Baron Von Doom is offline   Reply With Quote
Old 30-04-2006, 9:01 AM   #2 (permalink)
staffspete's Avatar
Thanks: Gave 37, Got 14
Was in the same boat as you , just bought the Panny 42PX60B and was running a Toshiba sd520e although a good player I wanted something to utilise the upscaling abilities we have these days and properly test this awesome tv.
I opted for the Oppo OPDV971H due to the feedback given on this forum.
Highly recommended for £179 delivered (IT Supplies).
Will tide me over for a year or two until HD DVD is more common place.
PIONEER PDP LX6090 Plasma / PANASONIC TH-42PX60B Plasma / SONY STR DA5200ES Receiver / MORDAUNT SHORT 908i Fronts, 905i Centre , 903i Bi-Polar Rears , 309i Subwoofer w QED wiring / CHORD Components / XBOX 360 Premium / SKY HD MULTI / TOSHIBA XE-1 HD-DVD / SONY PS3 / TRIPLE DRAGON Sat receiver
staffspete is offline   Reply With Quote
Old 30-04-2006, 3:45 PM   #3 (permalink)
thanks for the reply.
im not realy bothered about upscaling, especialy on a player this cheap. ive heard a few bad things about this player such as poor component picture and lip sync problems.
dont mind spending more than this as ive not set a budget yet. could probably be around £250-£300 maybe more.
Old 01-05-2006, 10:51 AM   #4 (permalink)
TarMoo's Avatar
Thanks: Gave 198, Got 331
Denon 1920 (I paid £228) if you can find one is stock somewhere. Excellent component picture.
Panasonic 42PHD8, Denon DVD-1920, Toshiba HD EP35, Sony PS3, Anthony Gallo A'Diva Ti, SVS SB12 Plus
Nikon D700 + Nikon 24-70 + 70-200 VR + 18-200 VR + 105 VR + SB800, Kata R102, Benro MC 68 + B0 Ballhead
TarMoo is offline   Reply With Quote
Old 01-05-2006, 1:35 PM   #5 (permalink)
Thanks: Gave 6, Got 2
Just ordered a 42PX60 from JL and will be getting a free DMRE15 DVD recorder. As the DMRE15 is Progressive Scan should I connect to the PX60 via component and will the TV do the upscaling to HD or should I bin it (not literally) and get a Samsung HD950 and connect via HDMI for upscaled DVDs?
I'm sure someone said that HD TVs upscale component inputs or have I misunderstood?
Not too bothered about DVD recording but would like some form of HD imagery on the new telly when it arrives.
paddcomp is offline   Reply With Quote
Old 01-05-2006, 3:09 PM   #6 (permalink)
the tv will scale everything to its native resolution. the samsung will upscale but it wont be proper high def, a good component output on a decent dvd player should give just as good a picture if not better than an upscaled one.
the only way for proper high def will be an xbox 360 or a pc, until hi def dvd or blue ray come out
dvd, panasonic, plasma
