This is a copy/paste of a post I did elsewhere on this subject. In the case in point, the TV was a 1280x720 device. If yours is (say) 1366x768, replace 720p with 768p (etc):
Fact 1: The signal encoded on all (PAL) DVD discs is 576i. That means 576 lines, interlaced.
Fact 2: The image displayed on your TV screen is ALWAYS 720p. That's 720 lines, progressive. This is the only image structure your TV can display.
To get from the one to the other, your equipment somehow has to
a) de-interlace. That means, convert from i to p (from interlaced to progressive).
b) re-scale. That means, (in this case) convert from 576 lines to 720.
Depending on your equipment, these two things may happen either in the DVD player or in the TV.
For example, if you feed your TV with a simple video signal (576i) then the TV will both de-interlace and scale it (i.e. convert to 720p).
Conversely, if you feed your TV with an already converted 720p signal, then it doesn't have to do this job, even though it can.
The only thing that might be gained by de-interlacing and/or rescaling in the DVD player (if it could) would be if it did a better job than the TV.
Nigel Except on matters of forum moderation, the views expressed in this post are my own, and do not necessarily reflect the opinions of AVForums. |
