Go Back   AVForums.com > Home Entertainment Players and Recorders > Blu-ray and DVD Players > DVD Players
Today's price checkPowered by
Sony DVP-FX730
LG DRT389H
Panasonic DMR-EX769 160GB
LG RHT497H 160GB
Sony DVP-FX730
LG DRT389H
LG RHT497H 160GB
Philips DVP3310
Panasonic DMR-EX98V 250GB
Panasonic DMR-EX79 250GB
Samsung DVD-H1080
Panasonic DMR-XS350 250GB
Sony RDR-HXD995
 More...Prices updated November 22nd at 5:30am and include delivery.
Old 29-01-2002, 1:45 PM   #1 (permalink)
bill1962
Posts: n/a
Pioneer DV444 and MP3 bit rate
I have ordered one of these and hope to have it by the end of the week.
Anybody know what bit rate the MP3's must be in order to play on this machine?
Will 192Kbits/s work?
Thanks,
Bill
Old 29-01-2002, 2:03 PM   #2 (permalink)
lmccauley's Avatar
Thanks: Gave 103, Got 95
I created a test CD with (I think) 128, 192 and 256 Kbps and they all worked on a 545. I'm currently ripping, encoding and burning MP3 disks from my CD collection. I'm getting about 5-8 albums per CD.
Cheers,
Liam
"Whatever tomorrow brings, I'll be there
With open arms and open eyes, yeah"
http://www.flickr.com/photos/lpmcc/
lmccauley is offline   Reply With Quote
Old 29-01-2002, 2:19 PM   #3 (permalink)
Anyone know if Dynamic encoding works ???? i rip all of mine with Audio Grabber and use the dynamic encoding - in case no one knows this increases the Bit rate where required and lows when its not needed - so the bit rate is constantly changing. That way i get best sound for the least amount of space - why encode no sound at 256 when it can be encoded at 56 for example.
Spike
spikeyboyo is offline   Reply With Quote
Old 29-01-2002, 2:26 PM   #4 (permalink)
lmccauley's Avatar
The manual says that variable bit rate isn't supported
Cheers,
Liam
Old 30-01-2002, 1:13 AM   #5 (permalink)
ice_cool's Avatar
I have used various cd rippers and mp3 encoders. I now use Exact Audio copy with the excellent Lame mp3 encoder.
This way i can encode mp3s at 128 CBR, 256 CBR, and 192 CBR, 128 VBR etc...
I have burnt all types to cdr and cdrw and ALL bit rate types work!
They sound very good. Quite amazing as some dvd players cut the first couple of seconds off the track! (CYBERHOME! ).
I have a pioneer dv545 though, so maybe the firmware on the 444 is different?
ice_cool
Chill, sit back and have a beer! Worse things happen at sea you know!
ice_cool is offline   Reply With Quote
Old 30-01-2002, 10:22 AM   #6 (permalink)
lmccauley's Avatar
That's interesting to hear. The manual for the 545 definitely says VBR doesn't work, so I didn't even investigate. I just used blade to encode at 256CBR. I might look into using VBR now, though.
Cheers,
Liam
Old 30-01-2002, 12:54 PM   #7 (permalink)
Id be very interested to hear if VBR works on the 444 as i currently have 4,000+ mp3's done at VBR - hadnt even though about if they would work on MP3 player or not seeing as they work fine on Winamp.
So if anyone can let me know it would be very much appriciated.
Spike
Old 30-01-2002, 1:09 PM   #8 (permalink)
Thanks: Gave 11, Got 1
VBR works fine as do all other rates I have tried up to 320kbps.
The on screen display reports 128k when playing VBR.
Audio:Tag McLaren CDT20R-T2L, AV32R-BP192, 100x5R, B&W 705 HTM7 CCM65, REL StrataIII + Behringer FBD
Video:Topfield TF5800 PVR, LumagenHDP, Pioneer 433MXE plasma, Sony HS20 90" screen
Other:HTPC
MattB is offline   Reply With Quote
bit, dv444, mp3, pioneer, rate
