Can anybody help??? any 'old-timers' out there that still use laserdisc
the problem is that i cannot play laserdiscs in the ANALOUGE format... digital is fine, on both optical and coaxial outputs. AC-3 works just fine too.
i can just hear some minor sounds when the amp volume is on max!!!
all internal connections seem sturdy and good.
The player is a pioneer CLD-959 (jap version of elite cld-97?), amp is pioneer VSA-E07. the player has been aftermarket modified to output AC-3, could this be the culprit. the player was bought second-hand so ive never known if it worked in the past.
Can someone offer any advice as at the moment i cannot listen to some much loved old pioneer/rca disco-vision discs!
heres hoping and thanks.
