Go Back   AVForums.com > Home Entertainment Players and Recorders > Blu-ray and DVD Players > DVD Players
Today's price checkPowered by
LG DRT389H
Sony DVP-FX730
Panasonic DMR-EX769 160GB
LG RHT497H 160GB
LG DRT389H
Sony DVP-FX730
LG RHT497H 160GB
Philips DVP3310
Panasonic DMR-EX98V 250GB
Panasonic DMR-EX79 250GB
Panasonic DMR-XS350 250GB
Samsung DVD-H1080
Sony RDR-HXD995
 More...Prices updated November 24th at 11:30am and include delivery.
Old 02-01-2006, 1:52 PM   #1 (permalink)
Thanks: Gave 28, Got 4
Question Best sub-£100 player?
Hi all
I'm looking for a cheap second (bedroom) DVD player - all I want is component out with PAL prog-scan and something that's easily hacked for multi-region.
I'm a bit out of touch with this end of the market - any ideas?
jchm is offline   Reply With Quote
Old 02-01-2006, 2:02 PM   #2 (permalink)
PJTX100's Avatar
Thanks: Gave 256, Got 280
People like the Limit player from play.com.
http://www.play.com/play247.asp?pa=s...C&title=509316
I'm not saying it's the best btw.
A man's life in these parts often depends on a mere scrap of information.
PJTX100 is offline   Reply With Quote
Old 02-01-2006, 2:46 PM   #3 (permalink)
ash
ash's Avatar
Thanks: Gave 630, Got 420
Pioneer 575 IMHO, it comes in black or silver colour, usually pre-hacked for MR.
Batman Begins at IMAX!
ash is offline   Reply With Quote
Old 02-01-2006, 6:37 PM   #4 (permalink)
PJTX100's Avatar
Is it still available for sub £100? Richer put them up to £120.
Also I'd imagine it would be very difficult to find a black one now unless a 2nd hand one became available.
Old 02-01-2006, 6:43 PM   #5 (permalink)
Walter Sobchak's Avatar
Thanks: Gave 96, Got 30
£100 here
http://www.hyperfi.co.uk/default.aspx?CategoryId=201
Walter Sobchak is offline   Reply With Quote
Old 02-01-2006, 7:04 PM   #6 (permalink)
Might be worth asking in your local Richer Sounds. They are up to £120, but they kindly sold me one that had been out on trial and therefore open boxed for £100.
Great machine, but I had a bit of a fright after doing a reset (to put it back to factory settings) and then lost the picture. Had to connect the video jack and then change the settings to RGB output so it would work through the scart!).
Axemeister is offline   Reply With Quote
Old 03-01-2006, 12:08 PM   #7 (permalink)
Thanks for your comments folks.
After trawling through some old threads here, I've gone for the Limit 900SE as it's currently a steal (and in stock) at £49.99 from Play.com
Thanks for the replies.
player, sub£100
