Ok, I'm definately going to be purchasing either a
Panasonic TX32LXD52 or a
JVC LT-32DS6BJ (currently leaning towards the Panasonic even though it doesn't have a VGA input). I am seriously looking into an upscaling DVD player to go with it.
Thing is, I'm wondering if I should hold off buying a HDMI player and just buy a normal progressive scan dvd player with component outputs, most people say there is next to no difference between the two, and as there seems to various issues with some HDMI players compatibility with certain panels, would a normal progressive scan dvd player be the safer option?
Here's the catch, my budget for my new DVD player is only £100. I will probably see an increase in quality to what I currently use regardless of my choice as I am currently using an el-cheapo £30 Pacific POS I bought from Asda! (oh the shame!).
What's the best DVD player I can get for £100 that will make my films look good on my 32" LCD panel?
edit: Just saw this on Empire Directs website:
Panasonic DVDS29EBS for £45, progressive scan with component out. Much cheaper than a HDMI player...
