Originally Posted by pprovart
I pressed the Video Mode button several times..
It cycles through Scart, SVHS and Component, but every other component input will be progessive..so i dont need the PSCAN button.
Pete
Just bought it from Ebuyer £20+P&P. Had the same problem regarding no Pscan button and I contacted Eltax and awaiting a responce but it seems you may have the answer.
Cannot try it as I am waiting for my component cables, but are you saying that when you cycle through the outputs that the first cycle is interlaced, and on the next cycle it is progressive, is that how it works ?
Does it stay on this setting for the next time you use it ?
For anyone interested, tried it with Scart on a CRT to test it was working and it seems a cracking unit for £20, quiet and quick and great picture, multi region out of the box.
