Go Back   AVForums.com > Home Entertainment Players and Recorders > Blu-ray and DVD Players > DVD Players
Today's price checkPowered by
Sony DVP-FX730
LG DRT389H
Panasonic DMR-EX769 160GB
LG RHT497H 160GB
Sony DVP-FX730
LG DRT389H
LG RHT497H 160GB
Philips DVP3310
Panasonic DMR-EX98V 250GB
Panasonic DMR-EX79 250GB
Samsung DVD-H1080
Panasonic DMR-XS350 250GB
Sony RDR-HXD995
 More...Prices updated November 21st at 8:30pm and include delivery.
Good DVD player for audio? RossBurton DVD Players 2 18-07-2004 11:11 PM
My review: Momitsu V880 High Definition DVD Player Ninjaman DVD Players 13 16-07-2004 8:45 AM
discrete code needed for toshiba sd900e dvd player jonnyv Remote Controls 0 08-06-2003 2:09 PM
One4all code needed for Tosh 210 DVD player! Noel Remote Controls 4 24-10-2001 8:39 PM
Old 10-12-2001, 10:57 PM   #1 (permalink)
julesHem
Posts: n/a
Question Reg 1 player & DVD code enhancement
I already have a Region 2 Tosh 3109 player which I am delighted with. Because I should like the option of buying DVDs from abroad, I was wondering if anyone could recommend a cheap and cheerful Region 1 player which I could use alongside the Toshiba. I understand that chipping costs about £50 and reckon that I would rather buy a second cheap machine. Also, does anyone know if this machine would cope with enhanced coding which I read is going to be introduced on some disks?
Thanks in anticipation.
Old 11-12-2001, 8:36 AM   #2 (permalink)
KAO
Posts: n/a
Why would you want to buy a 'cheerful and cheerful' DVD player (minimum 99 quid), when you could get far better quality by having your Toshiba chipped for half the price?
Old 11-12-2001, 8:50 AM   #3 (permalink)
Super Moderator
Thanks: Gave 464, Got 946
To be as near 100% sure of playing R1 discs as you can be, you might consider importing a "real" R1 player from the US.
But, be aware that such players will most likely only output a true NTSC picture, so your TV has to be NTSC compatible. Also, you will need a mains voltage transformer as the US mains are 110v compared to our 230v.
In reality, the £50 or-so chipping undertaken by people like techtronics is effective at making your R2 player multiregion. This is probably the cheapest, and most convenient option.
Nigel
Except on matters of forum moderation, the views expressed in this post are my own, and do not necessarily reflect the opinions of AVForums.
LV426 is offline   Reply With Quote
Old 11-12-2001, 8:52 AM   #4 (permalink)
julesHem
Posts: n/a
Question
I suppose I am suspicious that chipping may spoil the perfection of the Tosh which I have had since they came out and because the Cyberhome 528 is only £100 I thought it to be a good investment. What I would like REALLY to know is should I buy a cheap US DVD player so that CE on SOME disks from the US could be overcome.
Old 11-12-2001, 5:22 PM   #5 (permalink)
Reiner's Avatar
Thanks: Gave 2, Got 12
Well, I wouldn't be too worried about spoiling anything, usually a codefree mod does not do any harm to the player or it's performance. As well most new mods are RCE friendly ....
So if you ask me get your player modified, cheaper and less stuff on the rack.
Rgds,
Reiner
Reiner is offline   Reply With Quote
Old 13-12-2001, 11:20 AM   #6 (permalink)
Posts: n/a
Just because a player is NOT region 1 it does not mean that it cannot play R1 RCE disks
Case in point
Last Monday I recived "a Knights Tale" R1 RCE from www.play247.com (great Film) went to spin it, on my (modded) Sony 850d and Nothing exept a mesage saying that it would not play because bla bla bla .....
Ho well ..... So I dug out the Tectronics manual which told be to swich the player to STANDBY press SHUFFLE followed By 1 then press play.
3 minutes later after a couple of false starts Im watching the film.
Only a minor annoyance but I thought at least I can play it. Unlike my mate John who as a Unchipped multy Region Samsung 907, Or his step son Dan who owns a HIMAGE 2290 (which you can get for £80).
WRONG The disk spins fine on their machines without any buttons needing to be pressed.
So Buy a disk that you Know is RCE and give it a spin any problems and ether buy a cheap UK multy Region player (Dont Get an American DVD to expensive and dangerous ) or My advice get that toshiba Hacked by Techtronics.
If you really want a new player why not upgrade the tosh to a better machine(UK) but make sure that it will spin RCE.
Dont worry about the tosh not being as good after modding it will be Better.
You say you got the tosh so you could get Region 1? Is it therefore multy-Region (But not Hardware Hacked) if so read and thy this. http://www.techtronics.com/uk/shop/5...liminary-check
code, dvd, enhancement, player, reg
