Go Back   AVForums.com > Home Entertainment Players and Recorders > Blu-ray and DVD Players > DVD Players
Today's price checkPowered by
LG DRT389H
Sony DVP-FX730
Panasonic DMR-EX769 160GB
LG RHT497H 160GB
LG DRT389H
Sony DVP-FX730
LG RHT497H 160GB
Philips DVP3310
Panasonic DMR-EX98V 250GB
Panasonic DMR-EX79 250GB
Panasonic DMR-XS350 250GB
Samsung DVD-H1080
Panasonic DMR-EZ48
 More...Prices updated November 23rd at 4:30pm and include delivery.
Pioneer 545 - Have u seen this.... andypandy DVD Players 12 14-02-2002 5:56 PM
Pioneer 737, did I screw up? The Wall DVD Players 9 11-02-2001 3:56 PM
Old 08-12-2001, 11:28 PM   #1 (permalink)
leon's Avatar
Thanks: Gave 0, Got 37
pioneer 737
can the progresive scan on the 737 only be used if you use RGB.
I have a good quality svhs lead but if progresive works with rgb only then ill think of changing ,this is feeding a projector
thx
leon is offline   Reply With Quote
Old 09-12-2001, 5:17 PM   #2 (permalink)
Paul D's Avatar
Thanks: Gave 61, Got 113
Hi.
The progressive scan output only works via the "Component" outputs(The three coloured phonos at the back). And at this moment in time, only on NTSC discs.
RGB only carries progressive when used with a scaler/HTPC, when outputting a computer type signal etc.
I believe the "Skyworth" dvd player is the only player that can do this.
AKA "fulabeer"
Paul D is offline   Reply With Quote
Old 09-12-2001, 5:59 PM   #3 (permalink)
AVF Editorial Manager
Phil Hinton's Avatar
Thanks: Gave 608, Got 1,836
Originally posted by fulabeer
Hi.
Just to add to Paul's comments, the Denon 2800 can be hacked to playback pal progressive also, via a firmware hack.
Editorial Content Manager
Hardware Reviewer
ISF Certified Calibrator / THX Certified Professional
My Blog - AV Enthusiast - My personal opinions are not those of the AV Forums or any other related website.
Phil Hinton is offline   Reply With Quote
Old 09-12-2001, 6:44 PM   #4 (permalink)
leon's Avatar
THANKS
is there a great difference between (svhs) and component (both of good quality ) or is it minimal...
Old 09-12-2001, 7:06 PM   #5 (permalink)
Paul D's Avatar
Leon.
The good news is the difference is between Svideo and Component can be dramatic!.
The picture will be clearer, giving more detail. Plus the colours will be more saturated, and it also seems to help with contrast.
If i'm right in thinking you have the new SonyVW11HT, then it may be better to just feed it interlaced(non progressive) component from your Pioneer737. This is because that way the Sonys own "built-in" de-interlacer can do Pal/NTSC progressive, with the added 3-2 pulldown etc.
You may find the Sonys own de-interlacer is better than the Pioneers. Experiment and let us know!.
AKA "fulabeer"
Old 09-12-2001, 7:33 PM   #6 (permalink)
leon's Avatar
THX FOR THAT
another question ,the projector would need about 8 mtrs of cable (red/green/blue) (bummer i just spent £160 on a svhs cable )from qed.do you have any names of company that do all these wires rolled into one ,ill have to retrace these back into the ceiling and wall i would like the best quality ones like vandenhull or silver line ,if you have any web sites that i can look at i would be greatfull and prices ..................
thank you
Old 09-12-2001, 8:13 PM   #7 (permalink)
Paul D's Avatar
It might be better "borrowing" a Component lead first, since you spent so much on the Svideo lead. This way you could decide if the change wil be worth it.
I was using a "Vivanco Prowire" 10 metre Svideo lead. Svideo doesn't travel so well over long cables. The Sony does have a very good Svideo input decoder. So the high quality one you bought might not lose as much info as mine did etc.
The difference wasn't night and day as such.
I just found after swopping, i started noticing so much extra detail. Plus the picture had more "punch" and "3D-ness".
Going back to Svideo after a week "just to see" was like looking at a "photo copy"!. The picture went flat, and detail seemed hazy.
It was well worth the money "IMHO".
AKA "fulabeer"
Old 09-12-2001, 11:20 PM   #8 (permalink)
leon's Avatar
thx
thx
http://www.ronin100.pwp.blueyonder.c...s%20shots.html
Old 10-12-2001, 8:50 AM   #9 (permalink)
Super Moderator
Thanks: Gave 465, Got 946
Get your long cables custom made from Lektropacks. My 3xRCA > 3xRCA 10m cable cost about £70 from their best range. And it's perfect for the job.
Nigel
Except on matters of forum moderation, the views expressed in this post are my own, and do not necessarily reflect the opinions of AVForums.
LV426 is offline   Reply With Quote
737, pioneer
