Originally Posted by Jagzfan
I have a Denon 1920, hooked up via HDMi to my new Benq PE7700.
Will I get a better picture with HDMI set to 720P, or to 1080i?
I know progressive is meant to be better than interlaced, but not sure on this one!
Thanks for any info.
As Knight Byte says it's best to try each to see which looks best.
Theoretically...
576p will look best if the scaler in the PJ is better then the scaler in the player
720p will look best if the scaler in the player is better then the scaler in the PJ
1080i should look worse than 576 and 720 because you are scaling both in the player and in the PJ
...but in reality it's best simply to "suck it and see"...PJ
