Go Back   AVForums.com > Home Entertainment Players and Recorders > Blu-ray and DVD Players > DVD Players
Today's price checkPowered by
Sony DVP-FX730
LG DRT389H
Panasonic DMR-EX769 160GB
LG RHT497H 160GB
Sony DVP-FX730
LG DRT389H
LG RHT497H 160GB
Philips DVP3310
Panasonic DMR-EX98V 250GB
Panasonic DMR-EX79 250GB
Samsung DVD-H1080
Panasonic DMR-XS350 250GB
Sony RDR-HXD995
 More...Prices updated November 22nd at 11:30am and include delivery.
Sharp P50 Series worth buying HDMI DVD Player? f1005705 LCD Televisions 3 18-08-2005 12:20 PM
Connecting PJ to DVD Player & Sky+ Box NightFox Projectors 1 25-02-2005 10:46 AM
3 DVD's for £20 @ Tesco av_enthusiast DVD Bargains and Discount Codes 0 10-07-2003 3:20 PM
Old 09-10-2005, 1:19 AM   #1 (permalink)
BeelzebubUK's Avatar
Thanks: Gave 19, Got 8
Cheapest HDMI DVD player that outputs 480i/576i ?
It appears from my other thread that if I can get a DVD player which can output 480i/576i over HDMI to the DVI input on a Lumagen visionDVI then I can't go far wrong on picture quality.
So what options are there ?
I've already read that the Arcam DV29, DV79 and the Pioneer 868 can all do this but they are too rich for me.
Basically I don't want to pay any more than £450....preferably less. Do I have any options ??
BeelzebubUK is offline   Reply With Quote
Old 09-10-2005, 1:33 AM   #2 (permalink)
Repton's Avatar
Thanks: Gave 37, Got 137
Denon 1920
Repton is offline   Reply With Quote
Old 09-10-2005, 1:37 AM   #3 (permalink)
Originally Posted by Eomer
Denon 1920
Are you sure about that ? Haven't read anything anywhere to indicate that it can do 480i/576i over HDMI. Would be great if it can as that was my original choice of DVD player
Denon says "480p or 576p / 720p / 1080i" scaled via HDMI....or can you bypass the scaler ?
Old 09-10-2005, 1:39 AM   #4 (permalink)
Repton's Avatar
sorry, got it wrong.
only 480p/576p
Old 09-10-2005, 7:49 AM   #5 (permalink)
PJTX100's Avatar
Thanks: Gave 256, Got 280
Apols if this has been suggested but is an option to get your existing player SDI modded?...PJ
A man's life in these parts often depends on a mere scrap of information.
PJTX100 is offline   Reply With Quote
Old 09-10-2005, 10:46 AM   #6 (permalink)
Hasn't been suggested but I don't have an existing player right now (using Xbox/PS2). Moving house so have already sold my main TV, DVD player ready for a new system for the new house
But having SDI would cost more than one of the DVD players already mentioned.
£325 for the SDI mod
£200 for the Lumagen to have SDI module
And the players that can be modded aren't cheap either
Old 09-10-2005, 11:00 AM   #7 (permalink)
PJTX100's Avatar
Ah, I misread, you said Arcam CD player not DVD player...
Old 09-10-2005, 1:51 PM   #8 (permalink)
gandley's Avatar
Thanks: Gave 168, Got 287
Pioneer 868i
arcam dv79
pioneer 989
I am getting the 989 for this very purpose
Dustin.
gandley is offline   Reply With Quote
Old 09-10-2005, 4:46 PM   #9 (permalink)
Originally Posted by gandley
Pioneer 868i
arcam dv79
pioneer 989
All too expensive for me.
Old 09-10-2005, 5:23 PM   #10 (permalink)
gandley's Avatar
How about the oppo or the momitsu (or however it is spelt).
I do not think many HDMI players pass Interlaced via HDMI more so the cheaper units.
Dustin.
Old 09-10-2005, 6:53 PM   #11 (permalink)
Think I might just go for my original choice which was a Denon 1920 unless I can come up with a cheaper player that will do 480i/576i over HDMI which is looking unlikely to be anything cheaper than about £600
I'm sure I'll be more than happy with it after what I've been used to. It has everything else I need and is a good price.
Old 09-10-2005, 7:29 PM   #12 (permalink)
Thanks: Gave 16, Got 280
Why do you require an HDMI player to output 480i/576i, you could do a lot worse than getting a decent component player that will do this for cheaper money. The Pio 575 can do what you want for £100.
neilmcl is offline   Reply With Quote
Old 09-10-2005, 8:16 PM   #13 (permalink)
Its not a requirement - just a preference and wanted to be able to try out both HDMI and component from the same player. Also saves on component inputs on the scaler.....at the moment I'll have 2x DVI inputs on the scaler not being used.
Would be nice to have the option of both but at as the only players that can do it are £3-400 more than anything else its not worth it for me right now.
I think the Pioneer 575 will be on my short list.
Old 09-10-2005, 9:07 PM   #14 (permalink)
Thanks: Gave 819, Got 1,086
seen 868 go for £400 secondhand.....
Do everything with excess, even excess
Nic Rhodes is offline   Reply With Quote
Old 09-10-2005, 9:23 PM   #15 (permalink)
Don't worry - I will be keeping an eye out for a 2nd hand one. Have put a Wanted thread up just in case
480i or 576i, cheapest, dvd, hdmi, outputs, player
